Approach Vector
  • Approach Vector
    We have a "surprise" glich that we have never seen before. A porgram was created and we are using Surface points with 3 initial hits and 0 Permanent hits. Currently we are using 3.5 release2. We are seeing the approach vectors for the already established surface points changing by as much as 45° and then moving into the part. Though the actual vector values established by the initial 3 points never change in the command screen! CAN ANYBODY HELP WITH THIS ONE? just a note: If we retake a new surface point with the same locations and use 3 initial and 3 permanent hits the actual values are different between the two
    Cold Beer MMMmmmm........
    Dell Precision T5400
    Windows 7
    B&S XCEL
    WENZEL LH1512
    PCDMIS 2011 MR1
    Are you programming off a model? I've noticed that sometimes when you are close to an edge or surface knit, the vectors can get skewed.
    sigpic:eek: Bring out the comfy chair!:eek:
      The problem is you are using a porgram. Try a program
        I had something similiar happen this week. I was programming to a cad model, wrote the program came back in the next morning, and all of my approach vectors had changed drastically. I had it programmed to take straight line moves in the I & J vectors only. Came in the next morning and the darn thing had K vector approaches, and the I & J's were far from being straight moves.
        3.7MR1
        I might not love my job, but I love the ones it feeds!
          i have had this same thing happen while using an iterative alignment with a large search radius.
          Scott
