Probe head controller box
  • Probe head controller box
    Hey
    I have a brown and sharp CMM that lost power (Power went out at the shop) and when I restarted it the Probe head controller box PHC 10-2 flashes the power and stop light at the same time then goes back off the
    PHC dead in the water. machine wont do anything .Checked air pressure its fine . So what else ?
    Thanks in advance.
    fuses, all those boxes have fuses in them. If you didn't blow a fuse, then the power spike that caused the outage probably fried something important.
      The PH10 controller is switched off if the machine is in E-Stop. You might be looking at a symptom and not a cause. I suggest you try supplying power directly to the PH-10 controller to verify it is working properly if you want to check this part of the machine out.
      I assume you cannot do a machine start (or it shuts down immediately after doing a machine start - which is why the PH-10 flashes). You need to find out the error message from the controller.
      If your machine has a Leitz protocol controller then you can select 'Edit - Preferences - Machine interface Setup' and at the top right of the dialog is a button marked 'Terminal'. When you open the terminal window type the command STATUS and it should tell you what is troubling the controller.
      I doubt your problem is the PH-10 controller.
      • rballz24
        B&S controller shutting off
        by rballz24
        I have a B &S CMM running pc dmis CAD 2012 with B&S controller. When the machine is homing the machine start on the controller shuts off. Any...
        05-03-2015, 03:13 PM
      • bigtallanddopey
        CMM wont start,
        by bigtallanddopey
        HI people, hoping you can help me out here.
        Everything was working fine yesterday, came in this morning and switched the CMM on and waited...
        06-03-2015, 05:28 AM
      • 12345
        Machine down
        by 12345
        LK G90C - LK 2000 Controller
        Probe Interface PI-200
        Probe head controller PHC10
        Probe Head PH10MQ with TP-20
        Machine will...
        11-13-2009, 03:29 PM
      • sealevel
        Controller not starting
        by sealevel
        2005 B&S Image 7-7-7 with DEA controller. Today we had a blackout/power loss. Entire facility went dark (during program execution). Ok, power came...
        10-20-2012, 12:44 PM
      • Cookie
        Monday's
        by Cookie
        Morning all ,
        Came in to a machine down this morning. It will not even power the servos up.
        Any one have any ideas?...
        05-24-2010, 10:19 AM
