PH9 Alignment
  • PH9 Alignment
    Hi all!
    I just got a replacement PH9 after my other one crapped out. What is the best method for aligning the PH9 to the CMM?
    Thanks,
    Tim
    Thanks a million!
    Tim
    Put a LONG extension in the head, rotate it to A90B0. Place 'something' on the table, slowly move the machine back and forth watching the gap between the extension and the 'something', twist as needed, when it is good, tighten up the mount all the way.
      You could also double check the setting by following what Matt has described above & then come in from the opposite side with A90B180 & the 'gap' you leave between probe & 'something' should be the same for each probe’s position.
      Poleaxe
      Beware the environment you live in for it will shape you
      Be careful the friends you choose for you will become like them.
        Thanks! Now, re-read your post while looking at your avatar...
        Thanks a million!
        Tim
          Every night!
            Thanks, Poleaxe! That makes a lot of sense!
            Thanks a million!
            Tim
              Another way to do the alignment is to take a pencil and put the eraser in one of the holes on the rock, shift 90-180 and move the center of the probe over the pencil tip, raise the probe up enough to clear the pencil and shift 90-0 and see if the tip is still centered on the pencil when you move the probe in one axis.
              sigpic Eye Yam Sofa King We Todd It.
                And they said the pencil was obsolete! I'll give that one a try too!
                Thanks a million!
                Tim
                • Randy P
                  PH9 adjustments
                  by Randy P
                  OK now you know I have the old PH9! at 0,0 (bridge) straight down its not perpindicular to the table. A direction is ok (the 0-105 direction) and off...
                  05-18-2007, 11:12 AM
                • TKOFaith
                  Ph9/ph9a
                  by TKOFaith
                  Greetings!
                  Can anyone tell me if a PH9A Probe Head is compatible with a PHC9 Probe Head Controller? I currently have a PH9.
                  01-11-2013, 10:27 AM
                • TigerShark
                  PH9 Issue
                  by TigerShark
                  it is while I have issue with my PH9 .
                  when it is changing orientation, some times it makes Wierd noise ( Crack) inside the ball shape,...
                  10-23-2007, 03:41 PM
                • Randy P
                  PH9 and PH9a
                  by Randy P
                  I'm trying to switch from a PH9A to a PH9 on a Dea Gamma. Ph9A won't lock. Correct me if im wrong- pretty sure they are interchangable. Is there anything...
                  08-23-2010, 10:29 AM
                • Tim Baker
                  PH10 Upgrade
                  by Tim Baker
                  We have just upgraded one of our machines to a PH10M from a PH9. Are there any settings within PC-DMIS that need to be changed to get this to work properly?...
                  11-06-2013, 09:54 AM
