Ph9/ph9a
  • Ph9/ph9a
    Greetings!
    Can anyone tell me if a PH9A Probe Head is compatible with a PHC9 Probe Head Controller? I currently have a PH9.
    Thanks!
    Tim
    Thanks a million!
    Tim
    Yes, the ONLY difference between the heads is that the PH9A has the 'quick-change' mount system. Not a RACK quick-change, but still a 'quick-change' system.
      Wow! Thanks for the quick response and the information. I'd have been in a world of hurt if they weren't compatible. Boss man would not be happy!
      Thanks again!
      Tim
      Thanks a million!
      Tim
        Thanks again!
        Tim
        I have two PH9 and one PH9A, they works just fine on the same controller. HOWEVER, they are not the same 'build' probe-wise. If you are getting this as a back-up, I would suggest you make duplicate programs since the probe file for the PH9 will have a different length than the PH9A and have one program PH9 and one PH9A. The PH9A uses a quick-change adaper to get back to the 8mm threads that the PH9 has, and the adapter is like 25mm long, so it will add that to the over-all build length.
          Ouch! That's gonna screw me up on a few programs with tall parts. I knew I'd have to change the probe build, but I didn't realize there was extra length.
          Thanks for the extra info!
          Tim
          Thanks a million!
          Tim
          • Tim Baker
            PH10 Upgrade
            by Tim Baker
            We have just upgraded one of our machines to a PH10M from a PH9. Are there any settings within PC-DMIS that need to be changed to get this to work properly?...
            11-06-2013, 09:54 AM
          • Randy P
            PH9 and PH9a
            by Randy P
            I'm trying to switch from a PH9A to a PH9 on a Dea Gamma. Ph9A won't lock. Correct me if im wrong- pretty sure they are interchangable. Is there anything...
            08-23-2010, 10:29 AM
          • jflinter@snet.net
            Ph9
            by [email protected]
            Hello all,
            I'm fairly new to pcdmis and I am in a situation in work where we have a couple of new cmm's with ph10 probe heads and one...
            03-25-2008, 12:55 PM
          • W0QNX
            PH9 to PH10 upgrade costs
            by W0QNX
            We're thinking of updating the old PH9 with a PH10M head, will there be anything new software wise required from PCDMIS B&S? If so what and HOW MUCH?...
            08-26-2009, 03:29 PM
          • Randy P
            PH9 adjustments
            by Randy P
            OK now you know I have the old PH9! at 0,0 (bridge) straight down its not perpindicular to the table. A direction is ok (the 0-105 direction) and off...
            05-18-2007, 11:12 AM
