I have a part that looke something like an irregular cone. I have scanned up the sides of the part in 3 spots and I need to constuct circles at increments about ever .005 over a 1 inch section. The probelm i am having is creating the circles. I can not even seem to creat points on the scan segments in the areas i am expecting. Am i doing someting wrong?
constucting circles on scan lines
Use the "To Points" feature of the scan and make sure you start at the same depth on up. Your points should be level to eachother then change the workplane to what you need to construct the circles.I used to be high on life but I built up a tolerance.
Originally posted by John Kingston View PostCan you construct a cone from the lines? You then can construct a diameter from the cone at the heights you need.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
by c_beardenPCDMIS is not allowing me to construct a cone from 2 or 3 circles.....I am going to 3-different levels of a cone and measuring an 8-point circle at each...
02-14-2011, 02:14 PM -
by LikeCosmosHello I need your help once,
Functionally dependent on the element will not do, my 12 year old Mitutoyo software calculates internally to the individual...-
11-02-2012, 07:13 AM -
Hi guys, Does anyone know the best way to scan a Polygon bore so I can check the Runout of the bore to the flange face?. I don't have any CAD drawings...
01-20-2015, 09:03 AM -
by The DudeMost of the time I don't have a problem with this command, however, for some reason, today the software will not allow me to construct a cone from 2 circles....
10-16-2008, 11:08 AM -
by ROBB OVERBEYIs it possible to construct a cone from two circle's in a program? I have a part that i'm trying to find the diameter at a certain height on an angle....
08-14-2014, 11:38 AM -
