Iterative alignment
  • Iterative alignment
    I have been trying to do an iteritive alignment and I keep getting an alignment error. I can see in the code that it levels to z, but both rotate and origin are set to default. I have redone the alignment a few times but it gives me the same thing, can some one help me?
    Can you post the program code?
    sigpicIt's corona time!
      or the print?
      im gonna miss you bob....
        Use the points/features that you are using for the IT alignment to first create a non-IT alignment.
        Then create an IT alignment with those same points.
        If the first (non-IT alignment) works, then the IT alignment should work.
        If the first one doesn't work you can trouble-shoot that to figure out what you are doing to create the error.
        Lately, it occurs to me
        2017 R1 (Offline programming)
          This is the code, I know it is weird to call the features that but it is what is called out on the print.
          X_1 =AUTO/VECTOR POINT,SHOWALLPARAMS = NO
          THEO/149.9663,103.3344,13.5941,0,0,-1
          ACTL/448.665,-302.8474,752.6256,-0.2586758,0.2503697,-0.9329533
          TARG/149.9663,103.3344,13.5941,0,0,-1
          X_2 =AUTO/VECTOR POINT,SHOWALLPARAMS = NO
          THEO/-111.3693,-28.3572,-85.518,0,0,-1
          ACTL/177.0797,-426.4648,653.2536,-0.2531379,0.2486291,-0.9349357
          TARG/-111.3693,-28.3572,-85.518,0,0,-1
          X_3 =AUTO/VECTOR POINT,SHOWALLPARAMS = NO
          THEO/180.1663,-295.7333,659.609,0,0,-1
          ACTL/177.101,-297.5849,659.6827,0,0,-1
          TARG/180.1663,-295.7333,659.609,0,0,-1
          Z_1 =AUTO/VECTOR POINT,SHOWALLPARAMS = NO
          THEO/167.2597,-299.605,664.7056,-1,0,0
          ACTL/169.6734,-299.1191,662.6662,-1,0,0
          TARG/167.2597,-299.605,664.7056,-1,0,0
          TIP/T1A90B0, SHANKIJK=0, 1, 0, ANGLE=0
          Y_1 =AUTO/VECTOR POINT,SHOWALLPARAMS = NO
          THEO/428.026,-821.4994,763.5051,0,-1,0
          ACTL/430.0459,-818.675,764.786,0,-1,0
          TARG/428.026,-821.4994,763.5051,0,-1,0
          Y_2 =AUTO/VECTOR POINT,SHOWALLPARAMS = NO
          THEO/172.3264,-801.8699,815.6673,0,-1,0
          ACTL/174.7798,-799.0267,820.205,0,-1,0
          TARG/172.3264,-801.8699,815.6673,0,-1,0
          CLEARP/ZMINUS,24,ZMINUS,0
          A0 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES
          ALIGNMENT/ITERATE
          PNT TARGET RAD = 10, START LABEL = , FIXTURE TOL = 1, ERROR LABEL =
          MEAS ALL FEAT = ALWAYS ,MAX ITERATIONS = 3 ,LEVEL AXIS=ZAXIS ,ROTATE AXIS=Default ,ORIGIN AXIS=Default
          LEVEL = X_1,X_2,X_3,,
          ROTATE = Y_1,Y_2,,
          ORIGIN = Z_1,,
          ALIGNMENT/END
            This is the 1st alignment, notice my choices / answers Use the drop down boxes to change your axis and origin from default to "see below"
            ALIGNMENT/ITERATE
            PNT TARGET RAD = 0.5, START LABEL = , FIXTURE TOL = 0, ERROR LABEL =
            MEAS ALL FEAT = ONCE ,MAX ITERATIONS = 4 ,LEVEL AXIS=ZAXIS ,ROTATE AXIS=XAXIS ,ORIGIN AXIS=YAXIS
            LEVEL = MANPNT1,MANPNT2,MANPNT3,MANPNT4,,
            ROTATE = MANCIR1,MANCIR2,,
            ORIGIN = MANCIR1,,
            ALIGNMENT/END
              ALIGNMENT/ITERATE
              ROTATE = Y_1,Y_2,,
              ORIGIN = Z_1,,
              ALIGNMENT/END
              sigpicSTANDING CORRECTED IS THE ONLY WAY I STAND
                ALIGNMENT/ITERATE
                ORIGIN = MANCIR1,,
                ALIGNMENT/END
                I am picking the same features but when it prints the code to the report it puts in default instead of the features I pick.
                  ALIGNMENT/ITERATE
                  ORIGIN = MANCIR1,,
                  ALIGNMENT/END[/QUOTE]
                  Are you chosing your axis or using the default. Check level, using the pull down box check your axis that matches your cad model, choose your measured features and then click select.
                    Do you know why the actuals on X_1 and X_2 are so far out compaired to X_3?
                      Do you know why the actuals on X_1 and X_2 are so far out compaired to X_3?[/QUOTE]
                      I changed the ones on x_3 It wouldn't let me change the others.
                        I changed the ones on x_3 It wouldn't let me change the others.[/QUOTE]
                        changed what? the ACTUALS? You can't change the actuals. The THEO's? You can't just willy-nilly change the THEO (nominals) of features. You have to have the correct THEO's for all points in the program, including the points used in an iterative alignment.
                          changed what? the ACTUALS? You can't change the actuals. The THEO's? You can't just willy-nilly change the THEO (nominals) of features. You have to have the correct THEO's for all points in the program, including the points used in an iterative alignment.[/QUOTE]
                          Sorry I should have said I changed the vectors not the hit actuals.
                            do you have your find nominals turned on under F5
                              The relationship between your ACTUAL and THEO on these datum points does NOT make sense and here's why:
                              1, If you start off with your m/c co-ordinate system then you should always have huge deviation between ACTUAL and THEO, even with totally wrong ijk because your THEO is from CAD but your ACTUAL is obtained from m/c. So your 3 X points seem normal but how can those Y and Z points within 3 mm deviation from ACTUAL to THEO? That means the relationship between your X points and YZ points is already broken in ACTUAL readings.
                              2, If you just look at your THEO on 3 X points, these are 0,0,-1 points, the difference between X1 and X3 is more than 600mm, but the elevation in X,Y direction is much less, so pc-dmis will have tough time to use these 3 X points for level.
                              I'll suggest the following:
                              1, Double check your THEO values, re-think which points are reasonable for level;
                              2, Reset all ACTUAL value and run from scratch, just do the manual measurement, do go ahead with iterative alignment yet;
                              3, Look through your ACTUAL value to make sure they make sense under your m/c co-ordinate system;
                              4, If everything okay then go ahead with iterative alignment (with all axis set as default option);
                              It should work.
                              Best Regards,
                              Ray Xing
                              GDTP S-0605
                              CGP Certified (ITAR equivalent)
                              CMM Application Specialist
                              RX Metrology Solutions Inc.
                              One stop solution for self-paced Metrology training
                              www.rxmetrology.com
