hello all. i am having an issue dimensioning true position. the dimension calls for true position .010" max material condition to datum -h-/ datum -b- regardless of feature size/ and datum c. the problem is when i enter the tolerance for the holes called in the true position is (+.004/-.000) and then set up the feature control frame, there is no where to edit other features diameters. so the diameter for datum B is showing up on the report as +.004/-.000 when it should be +.060/-.000. i am using version 4.2, legacy dimensioning is off for this part of the program only as this is something new we are trying.
True position
Yes datums are defined and yes datum b is one of the first things to get measured so it is reported before the true position. but what do mean " size limits"??
xyz_ can you be more specific. maybe im skipping an important step. how can i modify the tolerances of a defined datum? that may be the problem
Originally posted by Onehot82 View PostYes datums are defined and yes datum b is one of the first things to get measured so it is reported before the true position. but what do mean " size limits"??
xyz_ can you be more specific. maybe im skipping an important step. how can i modify the tolerances of a defined datum? that may be the problemXYZ_IJK
pc-dmis 2012 mr1, 2013mr1
calypso 5.4 sp1
by mrwildebeastHi All,
Can anyone explain ( or point to an explanation ) of the maths behind a true position calculation, my gd & t knowledge is...-
05-16-2008, 02:01 AM -
by HirxmHello again.
Im trying to find the true position of these holes, they’re two and so far the program has already given me some results....-
10-14-2019, 05:25 PM -
by Jonathan SIf you were to report a true position for a hole in 2 axes using another hole as a datum, shouldn't the calculated deviation be the same if you align...
03-20-2006, 05:33 PM -
by zoolander303Using the new version and I have a strange red flag to me at least with my secondary datum deviation. Primary datum is a Cylinder in Xplus work plane,...
11-15-2020, 07:59 PM -
by JigneshI am making program in version 2010 in which I can select maximum 3 reference Datum as a 1st segment in datum feature frame. I am seeing condition of...
04-18-2016, 01:33 PM -
