We are running PC-Dmis 2010 MR2. I am trying to import an IGES file into my program that is 82.1 MB. When I import it in it shows up as just a big black blob. I am wondering if IGES file can be too big to use. I import models every day and this is the first one i have ever had troubles with but it is probably the biggest one I have ever done. If you have any suggestions it would be very helpful. Thanks.
Iges files (import translation problems)
There are 2 'ways' to import IGES into Pcdmis, try the other one, it will be in the settings page on the import. I would guess that you are getting un-trimmed surfaces. If the alternate import does not work, then they gave you a crap IGES file with all the garbage in it.sigpic
Originally posted by vpt.se View PostIt is possible that the "alternative" version isn't available in v2010.
Try exporting the IGES file (from your CAD software) with another configuration.
That is the setup window for IGES import - I thought you were referring to the two versions available under Import->IGES.
It used to exist two versions of the menu option IGES import, but the alternate way (that used to exist) does not exist any longer (which I thought you were referring to).PC-DMIS CAD++ 2o19 R1 SP11
Originally posted by vpt.se View PostThat is the setup window for IGES import - I thought you were referring to the two versions available under Import->IGES.
That's what I thought he meant also - the '2nd' method (which was actually the original one) was removed as it was a third part piece of software which hexagon had to pay a license fee for, for each seat sold. They removed it and set about making their own one comparable which took a few versions.
Back to the original problem though - have you tried close and reopen the program? (there was a version with a graphics issue which resolved itself by shutting and reopening the program)Automettech - Automated Metrology Technology
Originally posted by robertcolorado View PostAsk your cad people to give you a STEP file instead. Or YOU can translate into STEP if you have CAD knowledge. I have troubles with IGES files, for instance edge points do not work properly with IGES files in my system. STEP has never failed me.
I like using STEP files to!PC-DMIS 2011 MR1
Originally posted by robertcolorado View PostAsk your cad people to give you a STEP file instead. Or YOU can translate into STEP if you have CAD knowledge. I have troubles with IGES files, for instance edge points do not work properly with IGES files in my system. STEP has never failed me.(╯°□°)╯︵ ┻━┻
Originally posted by robertcolorado View PostAsk your cad people to give you a STEP file instead. Or YOU can translate into STEP if you have CAD knowledge. I have troubles with IGES files, for instance edge points do not work properly with IGES files in my system. STEP has never failed me.PC-DMIS CAD++ 2012 MR1
by Bob PierceJust upgraded from V4.0 to V4.1 We got downloaded thanks to help from this forum. Know another challenge of which I am ignorant in the problem.
03-06-2007, 08:23 AM -
by Mike EhelerHello, When I try to import an IGES file all the icons are Greyed out. Can anyone tell me why?
Thanks, ME-
08-16-2011, 02:32 PM -
by m.gomezAfter I import an iges into my program PC DMIS crashes... all I do is select impot, then choose the IGES I need, then It comes in, then I will hit save...
08-21-2014, 01:02 PM -
by Willy TGuess I need to import CAD models for PC-DMIS to make it easier on me.
The last attempt was IGES - our PC couldn't do the straight IGES,...-
03-18-2008, 12:55 PM -
by jonasI made an iges file in solidworks of a solidworks model, when I import the model into pcdmis the iges model has edges to it instead of round radiused...
09-25-2009, 01:42 PM -
