MIN Value on Max Inscribed Circle
  • MIN Value on Max Inscribed Circle
    Hello,
    I was wondering if someone could explain how the MIN value of a Max Inscribed Cricle is caluculate in PC DMIS.
    Correct me if i'm wrong but the min is the max inscribed diameter.
    I am currently using version 3.7
    Im not sure if I understand the question but would your max diameter on the feature be your max inscribed circle? A circle is derived from points and the smallest a diameter can be made from the points would be your min dia. and the largest dia. from the points would be your max dia. I hope that kinda answer your question.
    sigpicSTANDING CORRECTED IS THE ONLY WAY I STAND
      max size is the biggest circle that can be created with the points measured (least squares method), min is opposite.
      The actual is the size using the method you chose (max inscribed) which involves substituting a pin.
      How do you get such a massive form error on a hole?
      Map it out and you will see where the errors are and you will also see why the differences are so big.
      BTW turn off min max output unless you need it.
      See the difference in the z value using the different calculation types.
      min max is confusing the issue and is not relevant for most reporting outside of form and surface deviations.
      Roses are red
      Violets are glorious
      Don't try to sneak up
      On Oscar Pistorius.
      MIL-TFP-41C
      3.7mr3, 2012mr1, 2013mr1
      • Johnny C
        "maxmin" question
        by Johnny C
        If I measure a 24 point circle and output "maxmin" as a dimension parameter does this give me the min and max calipered readings (2 points of...
        01-26-2010, 10:05 AM
      • WolfMan
        Max and Min
        by WolfMan
        I am not near the CMM, so I cant really test this.
        If I were to measure a Circle with 12 hits. and if I were to report Min and Max value,...
        08-29-2017, 01:11 PM
      • Gabor
        Calculating methods of max/min diameters?
        by Gabor
        Dear All!
        I'm new here. I use PC-DMIS for a year. Earlier I used Zeiss and Mitutoyo softwares.
        All of softwares can calculate 5...
        02-21-2007, 05:06 AM
      • hertangel
        Min/Max
        by hertangel
        Hello,
        how do you report MIN or MAX id that's what the drawing asking.
        in other words the print calls for 25 max dimater.
        12-20-2011, 12:24 PM
      • cfranklin
        max & min
        by cfranklin
        Good morning all :
        When u print out a report, the max and min are supposed to display what values??? Is it the max and min due to the...
        01-30-2009, 10:35 AM
