I have measured a cone and now I want to find out what the angle is. How would I measure this. I tried Angle between but keep getting 90deg. What am I missing.
Cone Angle
An angle between the cone and another feature? or the angle of the cone.
Between features make sure feature and call out are done in correct work planes. Angle of the cone is dimensioned under Location>Pick your cone>check "A" for your dimension
BSWindows 7
Pc-Dmis 2015
Global Performance 7-10-7
you can't use the "angle" tolerance icon.....you have to go into the "Feature Location" like you are going to apply "X" and "Y" tolerancing. In there you pick the feature (your cone) and then check the "A" box and then "create"....you now have the angle of your cone. apply tolerance as needed
I had to ask the help line to get this one myself.....not a very obvious way to do this....
bobWhich one gets ridden today? MPH vs MPG..tough choice, both are FUN
Starrett RGDC 4028-24 :alien:
by Sp4mikeI’m having difficulty dimensioning a cone to a feature. It's a 15° cone with a flat top, the print is asking for the angle from the top to the cone....
02-11-2021, 07:25 AM -
by Curty_82ok so i programmed this cone to check the angle but it doesnt repeat anyone know why?
08-26-2008, 03:18 PM -
by JLHUTTI am new to the programing, first week, so this question my sound pretty basic. When I am checking an angle on a cone, I measure the cone feature and...
10-12-2007, 07:14 AM -
by J. LuskHow would you measure the angle of the face of a cone in relation to an adjacent plane? I'm getting a close but no cigar (48 deg. -vs- 50 deg.) When I...
08-19-2008, 04:13 PM -
by NasejhmoobHow do I dimension Cone angle? Can I dimension a 10° angle straight from an auto cone without having to make a line? Thanks
07-08-2016, 03:42 AM -
