I have a part with two bores. One of the bores is datum A. The other bore has a TP callout of .005 to A. I have one basic dimension from datum A to the bore.
So, I have measured both of the bores as cylinders and created a line between the two cylinders. I align the y axis to the line, set datum A as X=0, Y=0. When I do the TP of the second bore I get an X position as -.0008?!?
Shouldn't the X position be zero as it was used to create the line used for the alignment?
TIA
TIA
