Problems Printing to PDF
  • Problems Printing to PDF
    I hope someone has ran into this problem - I set up a program to print to pdf. Now I get an error message "Unable to load PDF drivers! Is cdintf.dll installed correctly?"
    I have printed to PDF before in other programs, but I've not had this happen.
    Anyone have any ideas???
    Bulldog40
    Try installing CUTEPDF writer, it acts as a printer, you set it in the print set-up window, it shows up as a printer in the list and it works quite well (and it's free!)
      I had the same problem with v4.1 printing to PDF. I could not find a solution so I uninstalled v4.1
        I tried the CUTEPDF Writer and that's not working. Would I have any issues if I were to re-install 4.0???
        Bulldog40
          Aside from what underspec has said, I would install 4.1 and then un-install 4.0.
          My .50 cents worth and I need change.
            Did you install the converer along with CUTEPDF?
            Perry
            B&S Mistral
            3.207 Beta on XP
            Older'n dirt
              If that doesn't work try installing UGLYPDF.
              PC-DMIS 2016.0 SP8
              Jeff
                I re-installed 4.0. Problem fixed. In the meantime Tech Support sent me the PDF250Converter that acts as a printer. Thats all I needed on that.
                Thanks for all you guys input.
                Bulldog40
                • randy z
                  Printing to PDF. Error
                  by randy z
                  I am getting the following error when trying to print the report out to a pdf file.
                  When I am outside of PCDMIS it prints to pdf with do problems....
                  06-04-2012, 01:29 PM
                • doo_hicky
                  Printing problems
                  by doo_hicky
                  An operator had somehow deleted the PCDMIS 2.50 converter off of the printer setup munu off the hard drive. Now when I go to print to a file I get an...
                  05-01-2008, 10:52 AM
                • THE ROOKIE
                  Pdf Printer Converters
                  by THE ROOKIE
                  HAS ANY ONE HAD PROBLEMS WITH THE PDF PRINTER DRIVERS? I KEEP HAVING TO REINSTALL THE DRIVERS AFTER EACH USE. IS THERE AN ORDER TO REINSTALL THESE DRIVERS...
                  05-22-2008, 01:32 AM
                • Chaddy7604
                  PDF driver problem
                  by Chaddy7604
                  Just upgraded from V4.2 to V4.3 everything appears to run as normal until the report is sent to save as a PDF file, now getting an error window with the...
                  11-25-2008, 05:43 AM
                • Darin Steiner
                  PDF problem
                  by Darin Steiner
                  Having a problem with saving reports to PDF. Unable to save a report that is more than 4 pages to a PDF. For example, I have a twelve page report and...
                  09-12-2011, 11:17 AM
