Export Scans
  • Export Scans
    Can you export data you get from a linear open scan as a DXF file? If so how would it be done?
    2B1ASK1
    Nope.
      I've done this with File | Export | DXF and gotten the desired results. If not you can use Export | IGES and then use the setup button in the iges export window to better customize what the data will look like in AutoCad.
      Requires pcdmis Cad
        Requires pcdmis Cad
        Oops, my bad, yep. When I looked at the export options, I saw DWG and missed the DXF that is part of the same export option.
