What should the calibration settings be for this page (screen dump below) as i may have changed some of the settings and now all the probes and angles are measuring around 0.012 microns under the nominal diameter of the selected tip??
Calibration Issues!!
Well, is it a NEW probe you are using? Is there a different piece of hardware in the build-up? Is it a new cal-tool? 0.0005" is not much, depending on your machine it is probably less than the machine is capable of measuring correctly (machine specs). The biggest thing you need to worry about is the STD-DEV as it will show an out-of-round condition of the calibration. You can basically double the SD for the out-of-round (this is what I have found on tests measuring the cal-sphere when NOT doing a calibration). Is the touch speed different? Is the prehit retract different, is the speed on the joy-box at the same setting it has been at? Lots of possibles in this case. HOWEVER, as long as you use the SAME move speed and the SAME touch speed that you just used in the calibration, then your touchs will give good data in your inspectino routine (same prehit and retract would be a good idea as well).sigpic
by VikingroovinDoes anyone know where I can find the recommended settings for a "full calibration" and a "partial calibration"? our Full calibration...
04-20-2016, 09:34 AM -
by AndyDaVeeHaving an issue with the diameter reading undersized .0015" only on tip A90B90 with all mods. All other angles are measuring OK. Tried a lot of things...
01-20-2015, 04:21 PM -
by sfieldWe got a Hexagon Metrology SF 7107 with PC-DMIS 2014 almost a year ago. Probe Calibration is run weekly with scans. I noticed recently that on at least...
09-01-2015, 11:06 AM -
by Ron OLoane
I am running v3.7 mr3
Ocasionally when doing a probe calibration on a program that has been executed 100's of times, the calibration...-
05-10-2006, 01:13 PM -
by JM1978I need some help. At first I got the error message, 'The calibration option is not valid unless all tips to be calibrated have already had a regular...
04-26-2017, 11:36 AM -
