I have a sheffield Discovery II using a Renishaw controller. Just installed v3.7MR3 and I have an issue I'm trying to fix. Before the install of this release, programs ran without having to re-press the auto button. Meaning after my programs end, it did not turn off auto mode on the RCU. Now, it does. Even after going into the settings editor and changing the "SendMNonManual" to "False" it still does this. I wonder if it's been hardcoded into this release? Any help?
PCDMIS Upgrade - Auto Mode on RCU
Are you sure that you have a Rensihaw controller on a Discovery II, that seems odd? Which Interface DLL are you using? Normally they have the SMP3XX controllers which are mounted on the back of the machine.
Originally posted by UnderspecYes I am using a Renishaw PHC10-2 controller on a Sheffeild Discovery II.
Since it is a newer Discovery with PCDMIS, you probably have the SMP 3xx CMM Controller. As pointed out, the controller you mentioned is the Probehead controller.
As far as your problem goes, the machine should not go out of AUTO mode at the end of a program.
Does it do this in all programs?
Does it do this in all programs?I used to be high on life but I built up a tolerance.
That is not a safety enhancement, that is a pain in the a$$. STI would not work if the CMM turned off the AUTO everytime. PCDMIS has a lousy way of telling you to turn the AUTO on (8 point font in the status bar at the bottom of the screen does not qualify as even adequate).
It is probably a bug. I cant believe that there would be a setting for that.
However, my understanding is that MR3 is still not approved by Sheffield to run on their CMMs. Are you running the correct Interface file?
hey, Brian why dont you speak up on this one??
Originally posted by cmmguyThat is not a safety enhancement, that is a pain in the a$$. STI would not work if the CMM turned off the AUTO everytime. PCDMIS has a lousy way of telling you to turn the AUTO on (8 point font in the status bar at the bottom of the screen does not qualify as even adequate).
hey, Brian why dont you speak up on this one??I used to be high on life but I built up a tolerance.
Call Sheffield direct dont call the PCDMIS tech support. Maybe there is a setting for this, but it sounds like a bug. Check with Sheffield to see which version of the DLL you should be using. With the Sheffields it is not always a good idea to use the latest dll off the wilcox website.
by DeWain HodgeDoes any one know if PC-Dmis is compatable with a Pantec Eagle Pro controller?
02-06-2015, 01:37 PM -
by caseybrusoHow do you know what kind of controller you have for your CMM? Is it the black box that says "Probe Head Controller". Asking because I am trying...
07-07-2017, 08:36 AM -
by tnguyenHi.
My Boss needs to replace or up-grade new Renishaw Controller . What is the best Controller and how much is it ?
I am using Brown&...-
10-04-2006, 10:59 PM -
by TuffshipLooking for a little advice on a cmm controller upgrade. We have a 12-20-10 Excel with a World Class controller running PC-demic + + 4.3.
Any advice...-
06-28-2012, 03:46 PM -
by bdanwallinI am attempting to run Modus on our Global with I++. I am having trouble getting Modus to recognize the machine. Has anyone out there done this?
07-12-2012, 08:43 AM -
