Slot TP?
  • Slot TP?
    Hello Folks,
    I have a slot that is one of my datums, "C". Dtm "A" is the face of the part, and dtm "B" is a hole.
    I construct cast points out of B & C, and my iterative alignment works fine.
    When I report out the slot, C, with using mmc, why is it that it uses the bonus tolerance of the width of the slot and not the length ?
    The alignment levels out to "A", rotates between "B" & "C", and origins on "B".
    I'm using ver3.7mr3.
    Should I be reporting out only the long axis of the slot, as the alignment rotates about this feature?
    I'd appreciate your input on this one. Thanks in advance!
    ZydecoPete
    I don't know why it did that with the width. And yes you are only reporting the distance, or one axis. the other axis has been zeroed out in the alignment, so you could also do a 3d distance
    You can construct a point from the slot and tp that
      set your cursor over the D (highlight it)
      and change it to LF
        What Jeffrey said: For some reason it defaults to D. If you want to true position the length, do what he said
        • marcc
          Position of round slot
          by marcc
          Hello, have been reading this forum for a while now, great source of information. Recently question came up about measuring method so I would like to...
          06-28-2017, 12:45 PM
        • Don juan Quixote
          slot true position
          by Don juan Quixote
          I have a slot with true position as follows.
          slot width .408-.468
          slot length .520-.580
          .030 mmc to ABC in the x direction.
          03-11-2009, 11:47 AM
        • JamesMannes
          Slot true position
          by JamesMannes
          Can the friendly folks of the forum help me out?
          Can you give a concise explanation of the slot true position call out I am showing below? I have...
          05-22-2006, 02:33 PM
        • gordon
          MMC on Slot
          by gordon
          I have a square slot with a TP call out using MMC. The way the slot is called out MMC is granted from the slot length.
          When I dimension the TP,...
          12-19-2008, 10:05 AM
        • JoBLOCK
          Slot ?
          by JoBLOCK
          I am have a brain fart. If you have a slot and you do a TPØ with bonus, which side do you use for BONUS the width or The length or both???
          05-20-2009, 10:14 AM
