After I run a part the execution icon and the execution command from the drop down list are not accessible. If I close the program and reopen I can execute it again.
Running CAD ++ 3.7MR1
I might not love my job, but I love the ones it feeds!
Does the execute options dialog box remain after the execution routine is complete? If it is it is "still executing". There may be a command it is having problems with or a corupt condition if that is the case. I have found issues when program lines are reached that define and recall viewsets if the graphics screen is not maximized.
The shortcut is Control + U pressed simultaneously. Execution will begin where the cursor is located.
There are several "bad" versions of pc-dmis out there, and only few good ones. (Unless you are a Hexagon employee, then they are all good.) I would only use 3.2063, 3.5MR2, or 3.7MR3. I think the jury is still out on 4.1. If your SMA has lapsed and you can't go to 3.7MR3, I highly recommend reverting to 3.5MR2. I do not know that the problem you are having is version related, but it very well could be. HTH
I believe there is a shortcut to start execution at the beginning of the program too. I don't remember what it is and am not anywhere near my machine right now.
Ctrl + Q. However if his execution button is not enabled there is something going on that Ctrl + Q will probably not cure. If his program is hung up on a line that is not able to execute he will get no error and his execute options dialog box will have nothing in it. I would suggest finding out if there is a particular line of code this occurs on.
Check to see that the program has actually ended. I've seen before where a comment has been added accidently to the end of a program and the inspector will sit there trying to figure out what's wrong
To me it sounds like your program is not ending properly. Check your code.
Thanks for the input, been out on the floor since I posted the message.
After I restarted the second time it started working again. I was sending everything to Datapage then printed my results. The "Advanced" Quality Engineer didn't like it becasue it didn't have the red and green on the report.
So I turned the print option back on and it's acting up again. **** Desk Jockeys
Hello to all. I can say that I know very little about PC-DMIS for I don't write codes or program at all, so I need some help from you guys out there in...
I updated my CMM to PC DMIS 2021. When I execute a program the execution dialogue box is hidden or does not come up at all. It seems like it starts to...
Is there a way to hide the execution box while a program is running? I'd like to be able to minimize pc dmis and not have to move this box around while...
