Hi -
I have a part up on it's side. I aligned and check everything on one side with the head at A90 B-90. Went above the part, rotated the head to A90 B90, and checked everything on the other side. When I run program in DCC mode, I rotate the head when prompted, and the first side ran well at A90 B-90. I rotated the head to A90 B90 when prompted, but the machine does not recognize the rotate. It shows the rotation in the tip box. The head is a manual rotating head (MH20i). Does a knew alignment need to be made after each rotation of the head, and does it also need to be calibrated each time it's rotated. Can I even rotate the head in the middle of a program?
