Ok, I was about to finish programing this F-35 part when Dims crashed and everytime I try to open Prg it crashes again. PCDLRN has encountered a problem msg. It seems I just waisted three hours of work! My boss not going to like me when he comes in... Anybody had this problem before?
Pc-dmis Crash
I don't believe you can open up the dims inspection report, unless it is saved somewhere with something other than .rpt. Is DIMS a standard extension that can be opened with some other software?
As a side note to the program problem. Try to delete the probe file and then re-open? Also, if you are using CAD, get rid of the CAD file and if the program re-opens just re-import?sigpic
Also, are you running XP service pack 2? If so, make sure the hotfix is installed (see Wilcox website). It seems to have reduced some of my PCDLRN issues.
I also still have daily PCDLRN problems that I must learn how to live with. So at the end of every day, I wrote myself a little batch program that copies all PRG and CAD files to a place on the file server. It has saved my *** a few too many times.
Originally posted by Jan d.Also, are you running XP service pack 2? If so, make sure the hotfix is installed (see Wilcox website). It seems to have reduced some of my PCDLRN issues.
Jan.
My $0.02. You were overcharged. Refunds are against policy. We appologize for any inconveniece caused by our greed and arrogance.
Originally posted by Wes Cisco3.7MR3 is very stable. Best version since 3.2063 (IMNSHFO). I have had less than 1 pcdlrn crash per month since I started using it. But I rarely have CAD files, so that may be a factor.
After deleting your probe file, you should be able to at least open the program....then rebuild your probe file.
This has worked for me almost everytime........Its frustrating to have to rebuild the probe file but instead of losing 3 hours programming time, you'll only lose 1/2 hour rebuilding your probe file.
This is making me wary of using 4.1
I have it installed on all machines but we're not using it yet......I think I'll stick with 3.7 MR3.............This is yet another example of why the SMA's are nothing more than us users getting the shaft!!!!!.....
Doberman
If the program crashes on open, you may be in screwed. The only chance is to delete the .CAD file and see if it opens. Sometimes it's the CAD file that gets corrupted instead of the program. If it opens after that, then just reimport the cad like before.
Stu
Originally posted by DobermanAfter deleting your probe file, you should be able to at least open the program....then rebuild your probe file.
Dobermanj/k
by dwadeWell things aren't going good this morning. I've had one DEMON crash after another. I am editing current production programs and save as new name for...
03-29-2008, 06:59 AM -
by RussLI can get around this by re-booting, and it's only happened twice in the past year or so. I'm just curious as to whether anyone else has experienced it...
01-19-2007, 07:59 AM -
by mattfurtawI had not run this program in quite some time and today when I went to open this up an error window poped up. I have never seen this before and it won't...
09-19-2007, 09:33 AM -
by qcfire65I would like to know if anyone knows if a bad CAD file can cause a program to crash every time. I have wrote (started writting - stopped after auto ailgnment)...
03-26-2014, 12:28 PM -
by lamboHi all.
I created a small part program a couple of days ago no CAD; I ran it a couple of times after it’s completed with no issues and...-
11-05-2010, 12:40 PM -
