Running V4.1. In report mode. If you hover over a dimension label and right click, you theoretically can get one of two different windows to pop up: One is called the "Label Properties" window where you can change the appearance of the label. The other is called "Report" window if you right click on label text. In the "Report" window, you can change a setting to ONLY print the out-of-tolerance features.
Here's my problem: in some of my programs, I can NEVER get this "Report" window to pop up. Whatever I try, I get this "Label Properties" window making an appearance again...
But on others, it just works like a charm!
This again baffles me. Has anybody experienced this before? Any work arounds? Are there other ways to instruct the report mode to only print out the out-of-tolerance features?
Thanks, Jan.
Thanks, Jan.
