I want to do a 3d best fit alignment using 8 constructed points I manually inputted with no CAD and no existing axis system in place. 4 are nominal values and 4 are actual values previously taken. When I try new alignment and best fit, select the 8 points, 3 Dimensional, Least Squares, weight of 1.000 to all, the result is no rotation or translation. Prior to trying best fit, the largest 3d deviation from a nominal point and it's actual partner is approximately .023". After best fit, I'm hoping to see an almost equal 3d deviation between each nominal and partner. What am I doing wrong? Thanks for any help.
3d best fit alignment problem
Originally posted by zox20 View PostPrior to trying best fit, the largest 3d deviation from a nominal point and it's actual partner is approximately .023". After best fit, I'm hoping to see an almost equal 3d deviation between each nominal and partner. What am I doing wrong?Last edited by DJAMS; 08-05-2012, 09:49 AM.
Thanks for the help. I did allow rotation and translation. DJAMs got me thinking. Edit the 4 constructed points of actual values and plug in their nominal values into their theoreticals. Then best fit again only using the 4 edited actual points. Now when I open the alignment to see the values, I have something other than zero. I'll verify the deviation lengths tomorrow at work. Thank you.
by keegoI have a long 8mm pipe with 14 bends in it. The print only has XYZ intersect coordinates of the bends and the 2 end points. I do a quick manual alignment...
06-02-2009, 08:11 AM -
by jksnappIs anyone familiar on how to do a best fit alignment with constructed points on tubes ??
09-05-2006, 11:44 AM -
by VinniUSMCAnyone want to take a stab at why a best fit alignment with all features perfect features somehow has +-0.100mm deviation?
ht...-
01-16-2020, 02:33 PM -
by Ahb723I am having an issue with a best fit rotation about Z, with translation in X and Y.
The program seems to be rotating in Z, possibly translating...-
12-04-2019, 07:49 AM -
by dph51NO CAD for this part.
I measured a part after creating contour nominals.
I then construct a feature set.
I need...-
11-17-2009, 11:27 AM -
