I have a family of parts that were programmed offline. They all have a tapered ID with a 5.67° included angle. When I measure using auto cone I get a "failed best fit calculation" message but if I manually measure the cone all comes out OK. I have tried to change the direction vector of the cone, the depth/height combinations and about anything else I can think of but I still get the error message.
Auto cone fails best fit
The CAD model is good. I've had this problem before with other parts but not to this extent. It is every time I run a part on any of the programs for this family.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
I can run the program if I use "feature>measured>cone" instead of the auto cone and the parts check good for the angle and diameters (gage diameter and height). We also measured the calculated thru diameter with pins and it is to size. I just can't get auto cone to run. I have even deleted the one in the program and inserted another at a different height and get the same thing.
I may take the part to one of our other CMMs and see if I get the same thing. It doesn't make any sense.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
by hwillyWhat is the optimum, best practise method of measuring a cone with PCDMIS?
At the moment, I'm just pressing cone, taking six points, then...-
02-16-2009, 11:38 AM -
by FutureManI'm trying to measure a small cone, 8MM dia X 5MM dia. In 3.7 I'm able to get points inside the cone (8, 10, 12, whatever) but when finished it gives...
09-10-2008, 01:55 PM -
by ScotsterHi there, I'm looking for a bit of assistance with a program I'm trying to create and prove.
I can't for the life of me get the "construct...-
01-17-2014, 05:20 AM -
We have Romer arm here with an RS3 laser on it.
I am having issues with the auto cone feature. I want to do an auto cone and then generate...-
Channel: PC-DMIS Portable
10-04-2016, 11:23 AM -
by AlexAI've got a very small cone to measure, I'd like to know how to program an auto feature cone (with confidence in the numbers) as I can't visually confirm...
12-17-2013, 09:41 AM -
