I've been fighting this for a while now. When you write a program using surface points and an actual thickness everything is just dandy. When you go back and run that same program, PCDMIS ignores the thickness. If you F9 or CNTRL-E the point everything works fine, but if you run the point in AUTO or CNTRL-U the point it ignores thickness. Has anyone else noticed this? If so what are your work arounds? I haven't tried this with vector points yet, but thats next to see if I can get around this.
Bill
Bill
