I'm just moving to 4.1 from 3.5 and in the calibration menu I see a "DCC+DCC" I looked in the help file but no listing that I see. Anyone know what this is for?
4.1 Calibration?
Originally posted by TestedI'm just moving to 4.1 from 3.5 and in the calibration menu I see a "DCC+DCC" I looked in the help file but no listing that I see. Anyone know what this is for?
What it does... If you answer "yes" that the cal shpere has moved you will be prompted to take a manual hit as usual. Then, it will take 3 DCC hits to locate the sphere more accurately than the manual hit. Then, it will progress with the 13 hits or however many you usually take for a cal.
If you answer "no" that the cal sphere has not moved it will take 4 DCC hits and then progress through the 13.
by SlimvinnOur IT folks installed 4.1 and had the same volcomp issue I found in one of the threads I searched.
My problem is: I cannot get the PH10M-TP20...-
08-30-2006, 11:54 AM -
I have been hearing at my work that selecting "Yes (DCC hits to locate tool)" is not an accurate way to calibrate the Master Probe. This person...
10-24-2017, 06:46 PM -
by 12345We have been having difficulty with manual hits on a particular machine
(global 12-22-10 - PC D-MIS V3.7 MR2 - XP SP3)
Seems if, say for...-
01-05-2009, 08:11 PM -
by Otto SquareI noticed that some of my probes are calibrating differently then others. Most take 9 hits around the equator, 5 hits @ 45deg, normal to the surface,...
02-12-2009, 04:57 PM -
by NMC_CMMHappy Monday All,
We have a recurring problem on the pfx machine with the tp200 head and PCDmis 4.3...
Basically, when calibrating...-
03-23-2009, 10:47 AM -
