Another one for you brainiacs...
Please review the attachment. Sorry for the funky colors. On the right there is a flat plane defined, called datum -H-. There is a 0.1873 hole called datum -J- and one called datum -K-.
As you can see, both have 2 VC's: one of location and one of orientation.
My question: when I evaluate the 2 holes on the left, what do I use for the VC on the datums when looking at the TP of those 2 holes?
My thought:
Datum -J-:
VC location: 0.1872 - 0.001 = 0.1862
VC orientation: 0.1872-0.0002 = 0.1870
I believe that in that case, 0.1870 must be used for the VC on the datum.
Same goes for Datum -K-. VC = 0.1870
Looking at PC-DMIS 4.1, it uses 0.1860 as the VC on both datums. It takes both VC's and it adds them. I do not believe that this is correct. It seems to me that in my case the VC for orientation ought to be taken.
The net result: PC-DMIS gives so much "wiggle" room on the virtual gauge that my TP's are almost always zero. I can be off by as much as 0.003" when evaluating with both datums at RFS, still with the VC, it wiggles so it brings it almost back to zero. Using only the orientation VC, TP becomes much more reasonable.
So the question is a simple one: is it correct to add both VC's when dealing with datums that have dual VC's?
Come on Mark F, you ought to have an opinion on this one!
Jan.
My thought:
Datum -J-:
Jan.
