1) You need to physically create one? Or 2) You need to create it in the Probe.dat file so you can build the probe file?
2A) I would save my original probe.dat file for reference as probe_091206.dat and set attributes to 'read-only'. Then I open it and save-as to probe.dat. Then I copy and paste the code for the item that most resembles my custom probe, then rename the 'pasted' item. Now edit the code to create the custom probe, (play with it, you'll figure it out).
Every couple of years I have to go down into the darkness that is building probes in PCDMIS...... Then it's studying and researching for awhile...before...
