Im using a XCEL 9159. It sat for years before making its way here so Ive had air hose after air hose pop off. I usually reconnect it then zip tie it. This morning the hose that connects to the left side air bearing came off. Its almost impossible to get to. Is it a bad idea to losen the air bearing so I can get to the hose nipple???
Air Hose off..
YES, it is a VERY bad idea to do that!
Get yourself some hemostats to re-connect the air line.
Then, on Monday, tell your boss that the machine will NOT keep running for very long unless they get it re-hosed. Just wait until one pops that you can not get to at all, then what do you do? Cheap hardware is cheap for a reason, you must expect to pay for repairs and fixes. TANSTAAFL!
Just imagine the damage that will be caused if you have an air-cylinder for the counter-weight and THAT hose pops off and drops the entire Z axis column right down to the table! CRASH!!!!sigpic
Your right, I work for a company that tries to cut every corner possible. Thats why my new machine runs V 3.0. I brought it up to him that we were going to have to get the thing rehosed. I got lucky with this one though. I got it on there one handed. Hopefully it will last.MIKE OXLONG
Originally posted by jaymunday View PostYour right, I work for a company that tries to cut every corner possible. Thats why my new machine runs V 3.0. I brought it up to him that we were going to have to get the thing rehosed. I got lucky with this one though. I got it on there one handed. Hopefully it will last.
Originally posted by bigjosh View PostSadly most companies are like that , most people dont know how touchy and tempermental CMM's are. I told my boss it was like a high maintenance girlfriend, from that point on I've had no problems getting service.
His reasoning:
Fun to play with.
Can be annoying as heII at times.
Costs a lot of $$$$.When in doubt, post code. A second set of eyes might see something you missed.
Originally posted by Matthew D. Hoedeman View PostTANSTAAFL:
There Ain't No Such Thing As A Free Lunch
Robert Anson Heinlein, The Moon Is A Harsh Mistress.
Thanks for the info.Actively looking to be a CMM guy again
Previously 4.3 MR2
XP OS
Is your problem a case of operator headspace?
by keegoThis morning my Xcel 7-10-7 started blowing a large amount of air from under the left side air bearing. The movement still seems ok but I'm sure something's...
09-28-2009, 09:18 AM -
I HAVE A SHEFFIELD 9.9.7 ,MY LEFT SIDE AIR BEARING IS MAKING A STAING ON THE TABLE IS THAT NORMAL?
01-11-2007, 04:21 PM -
I had an air line blow off the air bearing on my Brown & Sharp Xcel 7\10\7. Looks like the only way to replace is to loosen air bearing and spin...
08-27-2012, 08:10 AM -
by MIKEYHow much in your opinion, damage can be done if any, if the air shut off while cmm is running?
09-29-2008, 11:45 AM -
by hanssHi guys and hello, today my machine (B&S global) started making a pressured air sound while moving up in Z. It only happened for about 10 minutes,...
02-09-2011, 08:44 AM -
