Dimension with variables
  • Dimension with variables
    Ok got a small problem
    Is there a way to use a varible to set nominal to the dimension?
    I check a lot of spool lands 4 hits per plane and have a lot of new work to do
    Just got 170 new jobs that will be running about 14 per week
    The lands of course will be set at different X values. I have everything working the way I want it but the dimensions.. I want to use this program as a template.
    Code below
    C1X =COMMENT/INPUT,Please Enter X Value for Landing 1
    ASSIGN/V1X = C1X.INPUT
    C1V =COMMENT/INPUT,Please Enter X Vector Direction
    ,1 or -1 only
    ASSIGN/V1V = C1V.INPUT
    MOVE/CLEARPLANE
    PNT1A =AUTO/VECTOR POINT, SHOWALLPARAMS=NO
    THEO/V1X,-0.293,-0.107,V1V,0,0
    ACTL/-2.294,-0.293,-0.107,1,0,0
    TARG/V1X,-0.293,-0.107,V1V,0,0
    PNT1B =AUTO/VECTOR POINT, SHOWALLPARAMS=NO
    THEO/V1X,0.293,-0.107,V1V,0,0
    ACTL/-2.292,0.293,-0.107,1,0,0
    TARG/V1X,0.293,-0.107,V1V,0,0
    PNT1C =AUTO/VECTOR POINT, SHOWALLPARAMS=NO
    THEO/V1X,0.201,-0.239,V1V,0,0
    ACTL/-2.292,0.201,-0.239,1,0,0
    TARG/V1X,0.201,-0.239,V1V,0,0
    PNT1D =AUTO/VECTOR POINT, SHOWALLPARAMS=NO
    THEO/V1X,-0.201,-0.239,V1V,0,0
    ACTL/-2.293,-0.201,-0.239,1,0,0
    TARG/V1X,-0.201,-0.239,V1V,0,0
    C2X =COMMENT/INPUT,Please Enter X Value for Landing 2
    ASSIGN/V2X = C2X.INPUT
    C2V =COMMENT/INPUT,Please Enter X Vector Direction
    ,1 or -1 only
    ASSIGN/V2V = C2V.INPUT
    PNT2A =AUTO/VECTOR POINT, SHOWALLPARAMS=NO
    THEO/V2X,-0.293,-0.107,V2V,0,0
    ACTL/-1.841,-0.293,-0.107,-1,0,0
    TARG/V2X,-0.293,-0.107,V2V,0,0
    PNT2B =AUTO/VECTOR POINT, SHOWALLPARAMS=NO
    THEO/V2X,0.293,-0.107,V2V,0,0
    ACTL/-1.839,0.293,-0.107,-1,0,0
    TARG/V2X,0.293,-0.107,V2V,0,0
    PNT2C =AUTO/VECTOR POINT, SHOWALLPARAMS=NO
    THEO/V2X,0.201,-0.239,V2V,0,0
    ACTL/-1.841,0.201,-0.239,-1,0,0
    TARG/V2X,0.201,-0.239,V2V,0,0
    PNT2D =AUTO/VECTOR POINT, SHOWALLPARAMS=NO
    THEO/V2X,-0.201,-0.239,V2V,0,0
    ACTL/-1.84,-0.201,-0.239,-1,0,0
    TARG/V2X,-0.201,-0.239,V2V,0,0
    PLN1 =FEAT/PLANE,RECT
    THEO/V1X,0,-0.173,V1V,0,1
    ACTL/-2.293,0,-0.173,0.9999877,-0.0037317,0.0032802
    CONSTR/PLANE,BF,PNT1A,PNT1B,PNT1C,PNT1D,,
    PLN2 =FEAT/PLANE,RECT
    THEO/V2X,0,-0.173,V2V,0,1
    ACTL/-1.84,0,-0.173,-0.9999956,0.0019816,0.0021932
    CONSTR/PLANE,BF,PNT2A,PNT2B,PNT2C,PNT2D,,
    DIM LOC1= LOCATION OF PLANE PLN1 UNITS=IN ,$
    GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH
    X 0.000 0.015 0.015 -2.293 -2.293 2.278 <--------
    END OF DIMENSION LOC1
    DIM LOC2= LOCATION OF PLANE PLN2 UNITS=IN ,$
    X 0.000 0.015 0.015 -1.840 -1.840 1.825 <--------
    END OF DIMENSION LOC2
    Note the Nominals of loc1 and 2
    any ideas
    If I do the dimensions after the fact they pick up varibles fine just not as a template
    Tom
    Tia
    X V1X 0.015 0.015 -2.293 -2.293 2.278 <--------
    X V2X 0.015 0.015 -1.840 -1.840 1.825 <--------
    So you're saying when you put the assignments into the nominal output it doesn't change with the new assignment of the comment/inputs? Or did I miss read the post?
    "Your mom goes to college."
    Kip
      No even when I try it that way it will not change.. It leaves the v2x in place of the nominal
        So when you put your cursor over the variable in the output, it reads it as text?
        It seems to work ok for me.
        Kip
          No when I move the cursor over it it is correct.. It just doesn't show that way
            Oh Man I guess the Coffee didn't kick in yet... I forgot to switch to report mode.. All works fine.. Thanks Much
              Been there, done that. That very thing got me once as well. I followed the directions to the letter, then couldn't figure out WHY it was not showing a number on the screen, then saw it when I switched to report mode. It does make sense, otherwise if it didn't show your variable in EDIT mode, you would never remember what you did.
                Tom,
                You need to switch over to report mode. This should show your variable in the dimension block the way you want it.
                Craig
