I am new to using the scan command. I scanned a line and want to compare the line to the IGS file. Maybe show the igs file with a tolerance band around it with the scan as actual location?
How do I view scans?
Originally posted by Roger Taylor View PostI am new to usin the scan command. I scanned a line and want to compare the line to the IGS file. Maybe show the igs file with a tolerance band around it with the scan as actual location?
Insert / Report command / Analysis (pick your Profile dimension) / Apply Multiplier / Show All Arrows / View window / Insert Analysis View Command - from inside the analysis window.
Also from the same window apply MIN/MAX values to your analysis. View your report, it should be there. Have a play with it.Last edited by Liambo734; 05-31-2012, 06:02 AM.3.7mr3CAD++ / 2011mr1CAD++/2012mr1CAD++/QUINDOS7
by jonasIs there a way to show let's say a dotted line which represents nominal when dimensioning a profile of a line scan, some of the engineers don't get the...
09-28-2009, 06:06 PM -
by Chally72I have a scan that I have applied a profile dimension to, and I choose the graph option.
How can I get this graph, w/tolerance bands and...-
08-03-2009, 04:54 PM -
by hemirunnerI don't know if anybody else has had this issue but I create autofeature analog scans and it is about a 50% chance that when I do a graphical analysis...
10-09-2013, 06:45 AM -
by Jim PoehlerOut of the blue, pc-dmis has decided not to update the graphic display for analysis view in a recent program. I have never encountered that before, has...
05-24-2016, 05:00 PM -
by tnguyenHi.
I am using SP600 to scan profile around an inner gear. There are 0.05mm out fo specification. The Engineer want to know which point or area...-
11-06-2006, 05:14 PM -
