Radial Profile
  • Radial Profile
    I am running PC DMIS 3.7 MR 2.
    I have need to report Radial Profiles in a big way (most every part I do needs this). Unfortunately, I have not found a way to force PC DMIS to report in Polar Coordinates. That leaves me with only three options I can think of.
    1) Report normal Profile and calculate the radial displacement for the points. 2) Meaure the points as Individual Vector Points.
    3) Measure one point and Loop 35 times
    Neither of these are completely acceptable as I typically need to report every 10 degrees. Without a model that requires me to rotate my alignment 35 times and takes 25 individual points etc etc. Loops suck because I cannot find the points OR the alignment after the loop has completed.
    Does Anybody know of a better way to do this?
    Thanks,
    Bill
    Bill Jarrells
    have you tried paste with pattern with angular increments. then report your edge/vector points in T for the profile of each point.
      No. Paste with pattern is foreign to me. I have SEEN it done once or twice but have no idea where or how it is used.
      Bill Jarrells
        For paste w/ pattern, go to edit, pattern, enter your angle increment(sounds like 10 degrees in your case) and the number of times you want to repeat it. Then highlight and select the feature that you are wanting to repeat, right click it and select copy, put the cursor after the feature, go to edit and select paste with pattern, then it will put all the points in for you at the 10 degree increments. TADA!
        Mark Farren
          F1 will tell you how to use it.
            Yes, paste with pattern works rather well in alot of cases, as Mark stated that is really almost all you need to do to make it work. However, you must keep in mind that when you enter an angular increment, that it will translate about the origin, so if your feature has a center point that is not part of the alignment, make sue to set an origin there or you could have points in alot of places you don't want them.
            You can always do a linear open/closed scan to acheive what you are looking for as well. Simply calculate the max increment in inch/mm units that would equate to 10 degrees on that radius (i.e. 1 inch radius = max increment - .1745" = 10 degrees) and then generate the scan to points. Then you could just use T deviations for everything or even use the polar radius function and just set your +\- tols as bilateral profile tolerance.
            Disclaimer: All of my mathematical input should be taken as approximate values as it is Saturday morning and I am still feeling the burn from my completely forgotten Friday night.
            DCCFreak
            • keego
              Looping and Arrays
              by keego
              I need to report the Z values of several points on a roll form over a bearing. I'm taking one hit at <0,14.5,1> then copying that hit 36 times,...
              05-27-2009, 08:47 AM
            • BANDY
              Grid of points
              by BANDY
              Is there a way to create a grid of points on a selected surface. Something like 10 points in X direction and 30 points in Y direction and 1" apart....
              01-10-2008, 12:01 PM
            • Guest's Avatar
              Paste with pattern???
              by Guest
              Whenever I use any type of math to find a surface with paste with pattern I need to manually edit... Anyone else got any ideas.
              6 inch...
              03-31-2006, 07:58 AM
            • tszima
              2009 pcdmis rotate points 360
              by tszima
              Hi,
              I have a circular part with multiple planes, circles, and angles. I took all the hits in one line on the z axis up one side, to x-....
              09-27-2012, 11:17 PM
            • TKOFaith
              Paste with Pattern
              by TKOFaith
              Hey all,
              Running 2013. Recently upgraded from v3.2063. I'm attempting to use Paste with Pattern at 45° 7 times on a round pot. PCDMIS...
              10-09-2013, 02:53 PM
