How to program Jog Box
  • How to program Jog Box
    I just got a new cmm & A Brown & Sharpe Jog Box. The old cmm I used the bottom middle button was programed as "Erase Hit". The new Jog box has the same button programed to nothing. I was told that you can program the button, I was wondering if anyone can tell me how to program it to "Erase Hit"?
    I'm running 3.5mr2 with a sharpe 32 controller. If you have this then you can open DMIS go to edit/sharpe32 and it gives you options for your print button. Choose one hit apply & ok and your done.
      I`m running 4.1, I went to the seetings editor & went down to Sharpe 32 & found the print button & the value was already set to 1. I'm not sure if I did it right or it's just 4.1, anymore advice please
        Mine gives you the option for move point or done key....sorry no help from me.
          Originally posted by ptedrum
          ...the bottom middle button...
          Is this button labeled? F1? Print? something else?
            I'm using 3.7 and there you can go to edit/preferences/machine interface setup/sharp32. In there you can change the print button to erase,movepoint, or done. Not much help for you if they changed it around in 4.1 but maybe it will help someone else.
            sigpicOn the Obama Express. Next stop, the soup line.
              right now the button is labled F1, also have anyone else found that in 4.1 that when you try to open the help function that it crash pcdmis
                Sorry, can't help you. I haven't found anything to do with F1 yet and I am still on 3.7mr3.
                James Mannes might have an answer for you about the help file.
                  As far as I know, F1 is only for some controllers, but not the Sharpe controllers. I think it was for the LEITZ controller, but I am not sure.
                    Erase Hit
                    It will work on the fp2 and newer controllers on the globals,
                    but not on sharpe 32 controllers.
                    GLOBAL FX 12-15-10
                    3.7MR3, XP/SP2
                      That sucks because I have a Sharpe 32 controller
                        Who told you that you could program the buttons? I'd give them a call and ask them if they can tell you specific step by step instructions to walk you through it.
                        I'm guessing it was a sales rep who promised something he/she couldn't deliver.
                          It was one of the guys that calibrated the machine when I got. Good advice I need to give him a call about a few other issues, like on pick up if I touch off on a tooling ball or align. bushing and donn't come off on the same vector I came in on the machine will just stop then I have to hit the emergency stop button and move the machine by hand. Has anyone else had that happen to them?
                            Not that it matters but, a sharpe32 controller on a "new" machine? I thought that was old stuff?(I too aheva sharper32z so I'm not knocking your equipment). Anyways, as far as hitting F1 for the help files and it kicks you out? Something didn't load correctly if at all. Contact BNS, if you are loading 4.1 you have a software contract. They can help where us ham-fisted goons can't.
                              [also have anyone else found that in 4.1 that when you try to open the help function that it crash pcdmis]
                              Every CMM I've worked with (3) that had PC-DMIS, has crashed when I hit F1 or the help button. I've always thought it was just a glitch in the writing of PC-DMIS that's caused the problem... As it turns out, coincidentally it's been (from what I've heard) an inadequate graphics card or driver. It may be combined with the controller as well but as has been my experience thus far, exclusive to the graphics.
                              I've learned over time and crashes, to never ask for help from the F1 option... Come here first... But that's just me...
                              Thomas Stewart
                              Quality Technician/CMM Programmer
                              2010 MR1
                              Mitutoyo BN715
                              CMMC-3 Controller
                              • bigjosh
                                programming jog box
                                by bigjosh
                                I have the "normal" B&S jog box and want to program the print and done buttons . I have the print button set up to insert move points ,...
                                06-19-2012, 10:20 AM
                              • Stephen Andrews
                                Jog Box Help!!!
                                by Stephen Andrews
                                I am currently running a Brown and Sharpe Xcel 7/10/7 with the standard Brown and Sharpe Jog Box. I guess someone knocked the jog box off the table,...
                                07-09-2012, 02:03 PM
                              • Farmer
                                Jog Box
                                by Farmer
                                Hi, Im fairly new to Dmis. I have only completed the basic training, so apologies if this is a silly question. Is it possible to re-programme the jog...
                                06-29-2006, 04:08 AM
                              • Joe Zastrow
                                done button
                                by Joe Zastrow
                                Sharpe 32 PHC 10-2 B&S XCEL 7-10-7 dmis 4.1
                                My done button on the jog box has stopped functioning. It worked yesterday WTF I have...
                                07-19-2007, 12:48 PM
                              • 56flh
                                Jog box "print" button
                                by 56flh
                                I may be overlooking something obvious, but it seems I've lost the ability to insert a move-point into a program by pressing the "print" button...
                                07-19-2006, 11:38 AM
