Learning hyperreport
  • Learning hyperreport
    Is there more info out there on how to learn hyperreporting in pcdmis?
    the info in the help file is a little bit lame
    4.2mr3 CAD++ "Mr buggy(er) as we call it"
    If you plan on upgrading to 4.1 its said to not support hyper reports.
      thankyou for that piece of information. so there are no sites,books... on how to learn hyperreport or ???
        I did a quick (very quick) check on the wilcox site.http://wilcoxassoc.com Didn't see anything, but you may want to dig deeper. I think there is info in the PC-DMIS reference manuals.
          Forget it. I tried a couple of months ago, and didn't have much success. You're right, the tutorial within PC-DMIS is pretty vague. I ended up using Saved Viewsets and Screen Captures To Clipboard, and pasting everything into Word.
            Go here and scroll to find the download for the HyperReports
            Contura Calypso 5.4
              Guess I didn't look very hard!
                Thank God It's Friday
                Contura Calypso 5.4
                  If you pm me vektor I can help you out.
                  I use hyper reports for all outputs and have them singin and dancing. I had to spend hours teaching myself how to use them as the standard reports were no good for the "supervisors" in our shop, generally speaking they are one step up the ladder from the amoeba.
                    Congratulations Jon_dav... At least yours are heading in the POSITIVE direction
                    Thomas Stewart
                    Quality Technician/CMM Programmer
                    2010 MR1
                    Mitutoyo BN715
                    CMMC-3 Controller
                      This is partially true. In 4.0 and higher you can no longer edit hyper reports inside PC-DMIS. You can still, however, execute hyper reports within PC-DMIS 4.x. Also, much of what you could do in hyper reporting you can continue to do in the Forms Editor. See this post here for more info.
                      http://www.pcdmisforum.com/showpost....5&postcount=29
                      As far as learning Hyper Reporting, probably the best thing to do is take a training class on it.
                        Yes this is all true, but if you haven't started using hyper reports alot yet, seriously think about what your getting into.
                        We use them for 99% of our programs, they are wonderful to have, as someone put it, for the supervisors and operators to easily read, and you can customise them anyway you want......But, and there is always a but....
                        the hyper reporting fuction can be a pain in the behind, as we have found out since switching to 3.7. We have a brand spanking new computer, multiple processors etc., and still we crashed on a regular basis--by this I mean several times in one day.
                        We found that since our hyper reports/programs were all on our server (to assure the higher-ups that everything is backed up each day, and they want all info on the server), we had communication problems.
                        We eventually had to move all the programs/reports to the local computer, and we still crash about 2 times a week. (much less is we re-boot the computer at least once a day)
                        I suspect that we are not the only ones who were/are having these problems, otherwise why would B&S decide to get rid of the hyper reporting function?!?
                        Are you under sma, what version are you on now, and will you remain on that version for awhile?
                        If you go to using hyper reports, and then switch to 4.1, you will be SOL to create new reports.
                        From what I understand, there is an inspection report function within the new versions that will be similar but more user friendly.
                        I will be awaiting that myself, but as 4.0 is gone with the wind, and I will not go to 4.1 until is has been tested by many folks here and reported on (positively), so it may be some time before we switch over.
                          Just an idea, but I found a few years back that I was having issues similar with the crashes, and I started using powerpoint slideshows instead and the problem seemed to go away.
                          I can't be positive as I was never able to gather any supporting evidence to back this, but, my belief is that because hyper report depends on .bmp for photos, which are huge, plus the need to not only store the hyper report which many times contain active x objects plus the original .bmp that this is a whole lot to deal with for a local drive, unless the drive they are kept on is a secondary drive independent of the OS, strictly for storage. But as I said, the powerpoint slideshows have worked for me for quite awhile and they are much easier to incorporate into the program through ext objects menu and they are alot smaller in size. But, if powerpoint isn't an option, I would say get a 80 gb hard drive or larger, install it as a slave and keep it strictly for local storage. This is the same situation I warn ppl of when it comes to storing mp3 or any live media format on their pc. Best bet is to keep that stuff away from the OS, and just maybe the crashes might stop.
                          Just my .02
                          DCCFreak
                            Ouch! (Former VB Programmer 7yrs! )
                            "The difference between a banjo and a chainsaw is that you can tune a chain saw."
                              Maybe I was being a bit harsh with the above statement.....I apologise wholeheartedly to all the amoeba out there
