user defined hits
  • user defined hits
    v3.7MR3
    can't click and drag hits around on a square slot.
    works in 4.1. trying to change the depth on the two side if this square slot configuration.
      Winston,
      I've had the same problem using ver3.7mr3.
      There have been times when I wanted to use 3 surface sample hits, but I wanted to drag them to a different location and could not get it to work.
      Would you know if ver4.1 is now stable??
      Regards,
      ZydecoPete
        its stable but the reporting is totally revamped and you problably won't like it.
        • Peter Warcholyk
          User defined hits?
          by Peter Warcholyk
          Good Morning to All,
          Using v3.7mr3.
          When taking surface sample hits, I know that it is possible to change the position that...
          03-21-2006, 10:07 AM
        • rebeldude
          Move Sample Hits
          by rebeldude
          Does anyone knw if there is a way to manually move sample hits around a slot on version 3.7 MR3? I know you can select a sample hit on the cad, right...
          04-10-2006, 06:46 AM
        • Rascal
          Sample Hit Help
          by Rascal
          Im looking for some help with sample hits. i have an inlet plate with a Slot i want to have 3 sample hits and a 6 point slot. i kick DCC mode on Toggle...
          11-19-2012, 03:17 PM
        • Perry Fisher
          Programming slots revisited
          by Perry Fisher
          I'm programming a part with a series of slots. My customer does not use a CMM to check parts so the slot locations are to one end and one edge instead...
          01-13-2009, 10:48 AM
        • A Disho
          Auto Square Slot
          by A Disho
          Good Morning Ladies & Gentlemen,
          I am runing 3.7 , done iterative alignment for sheet metal part ( co extruded part).clamped in fixture .0.60...
          07-18-2006, 09:08 AM
