operator mode
  • operator mode
    Does anyone know how to change the printer setting in the operator mode. I want to change the default printer. I change it in programer mode then save the program and then use the operator mode and the printer changes
    Running 3.7 mr2 on a global image
    Since I gave up hope I feel much better !!!
    Go to control panel and set whatever printer to default. Should run any program.
      This is what I do. I log on as administrator and give the log on for the operators full edit privileges. Then I log onto the operator mode, Then I set the default printer, then I log off and log onto the administrator mode and take the privileges away again, Then when you log back onto the operator mode you should be good.
