I need to create a point where a circle and a plane meet. I have tried everything I can think of. The point should be at the tangent point of the circle and plane. Any thought's on how I might do this.
Thanks
To add to Winston's reply, measure a line on the surface. Then construct a pierce point from the line and circle. If the point is on the opposite side of the circle than you want, construct a reverse line from the original line then pierce the reverse line and the circle.
In some older versions, you need to construct a cylinder from the circle(cast) then do the above.
I don't believe they are. I am still fairly new to this. I did some of the things mentioned here and started getting the results I was looking for. I created lines from the plane then did a peirce point to the circle. That seemed to do the trick. Thanks for all the help.
I have tried to upload a screenshot from dmis, but I don't think it worked ( or maybe it worked twice...hmmm) anyhow,
I have use the last circle I just measured in a prg for this screenshot.
You can create it as a point or a line, whichever suites your needs at this time
(I may have to practice my uploading skills - never used it before)
well, I got the picture in, but the quality is sooooo poor, it's living in a shoebox!
TANGENT =GENERIC/POINT,DEPENDENT,RECT,$
NOM/XYZ,0,46.562,0,$
MEAS/XYZ,15R_METAL.X,15R_METAL.Y+15R_METAL.R,15R_METAL. Z,$
NOM/IJK,0,0,1,$
MEAS/IJK,0,0,1
DIM TANGENT1= LOCATION OF POINT TANGENT UNITS=MM ,$
GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH
AX NOMINAL MEAS +TOL -TOL DEV OUTTOL
Y 46.562 46.562 0.500 0.500 0.000 0.000 ----#----
END OF DIMENSION TANGENT1
TANGEN_LINE=FEAT/LINE,RECT,UNBND
THEO/0,46.562,0,0,0,1
ACTL/0.056,46.562,-0.27,0,0,1
CONSTR/LINE,CAST,TANGENT,46.562
DIM TANGENT2= LOCATION OF LINE TANGEN_LINE UNITS=MM ,$
END OF DIMENSION TANGENT2
need help constructing a pierce point. when in create the pierce point it creates point in center of the circle not on the inside where I need it to be....
In 2016 cad++ I used to be able to construct a pierce point from an auto circle right on the tangency of the circle, in 2018 I noticed when I try this...
Any help is appreciated as I have been wrestling with this one for a while. Last time this issue came up we ended up using a comparator for the inspection....
