Can someone please tell me why I can't get "move all" to work. I am using version 3.5MR2 on an Xcel machine with a PH10Q Renishaw probe head, I am not sure which controler. I don't care is it moves the machine and probe head in relation to each other as in sweep. I just want to be able to change probe angles during long drive moves. When I enter the command and try to execute it, I get the execution dialog box but nothing happens, it just sits there until I hit cancel.
Move all won't work
Matt, I asked the other operator, that has been here for a few years, if he has ever gotten it to work. He said "You mean that on the fly mode?" I took that as a no and proceeded to tell him what move all was. He said that he has never tried to use it. How can I tell what controller I have? If I have a controller that doesn't work with this command I will give up. Otherwise, I am going to send this problem to training along with our newest programmer.Thanks
Sean Steele
from F1
Inserting a Move All Command
The MOVE/ALL command
will function with any
motorized probe head -
continuous or
indexing - and any probe
combination.
The Insert | Move | Move All menu option inserts a MOVE/ALL command into
the Edit window.
A MOVE/ALL command is the same as a MOVE/POINT command combined with a
TIP/ command. This command has the benefit of rotating the probe head together
with machine movement.
When using a wrist device (PHS, CW43L, or CW43) this movement is synchronized
such that the wrist's AB movement will start and end its motion at the same time that
the machine starts and ends the X,Y, and Z movement.
When using this command with an indexable wrist such as a PH10M, this movement
cannot be synchronized and will occur at an unspecified time during the machine
movement (depending on time delays in the signal processing of the electronic
hardware). Because of this, the AB wrist movement may not always complete by the
time the machine performs the X, Y, and Z move.
The MOVE/ALL Edit window command looks like this:
MOVE/ALL,X,Y,Z,TIP=T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0
· X,Y,Z allow you to specify the X, Y, and Z coordinates to which to
move the probe.
· TIP= T1A0B0 shows the AB wrist movement to perform.
· SHANKIJK = IJK allows you to specify the shank's vector.
· ANGLE=0 specifies the theoretical angle.
Note that the probe head angle will usually be a predefined TIP position.
You should be able to get the controller type by looking at the installed modules. I think it is CUSTPROG.EXE and it should be in the install dorectory of Pcdmis. Run it and then you will see a drop-down window and in that you can find WHICH controller you have.sigpic
by dwadeRefurb PFx with new FB2 controller running V4.2mr1 and cannot get the MOVE/ALL command to rotate the probe head. If I take out the MOVE/ALL command and...
12-07-2007, 07:22 AM -
by blewisI am using PC-DMIS 4.1 on a Sheffield D-28 with a PHC 10-2 controller and a PH10T head and can not get a Move All command to work. It may be that I do...
10-02-2007, 08:10 PM -
by Mark_MR1OK, I've done the search, and didn't really see what I need.
MANRETRACT/2.54
Apparently my CMM doesn't recognize this command....-
01-04-2016, 02:34 PM -
by lamboDoes 'Move All' command work on your machine?
It does not work on Sheffield Endeavor 9.12.10 with PH10MQ probehead.
Add on: I should...-
05-13-2008, 01:15 PM -
by rolsartomFired up the cmm this morning all was fine, until a few minutes later, my controller box started making this loud humming noise, thoughts or ideas on...
10-23-2008, 10:06 AM -
