Have this part, see attached photos, -A- is the flat area between the inner and outer edges, -B- is the hole where the trihedron is located and -C- is a hole approx 38" from -B- and aligned to -B-. The outer surface is a contour surface, not necessarily a radius, it is also slightly angled in towards the -A- plane. The .098" diameter holes that go through this wall are called out TP .020m ABC. The wall thickness is .080". My alignment is set up per the datum structure, CAD=PART and all is good. My question is what would be the proper axis to tolerance for the true position of these holes through the contoured surface? There are no linear or radial dimensions to the holes, just the TP call out. Mind you that these are not located on a radius surface, there in lies my confusion of which axis to use for location. If this is unclear, I can attempt to explain it better or add more screen shots.
3.7 MR2 on a Global Image
