I Am Checking Three Variables Exactly The Same On One Part And Reporting Out Each, D1, D2, & D3 And Running 30 Parts. What My Boss Wants To See In Datapage Is All Three Combined Together. Instead Of Having D1, D2, & D3 Showing On The Statistics Report, He Just Wants To See One Report. Is There A Way To Combine Them All Together In Datapage? The Samples Have Already Been Ran And The Data Is There, Its Just Not What He Wants To See.
Datapage
Nope, you can not 'add' different 'variables' together to get a combined, one value report in Datapage. If they are 3 different variables, then you need to tell your boss that they HAVE to be reported as seperate variables since they ARE NOT THE SAME.sigpic
Originally posted by Matthew D. HoedemanNope, you can not 'add' different 'variables' together to get a combined, one value report in Datapage. If they are 3 different variables, then you need to tell your boss that they HAVE to be reported as seperate variables since they ARE NOT THE SAME.sigpic
PCDMIS 4.1, 3.5mr2,
If you want to add the 3 variables together, open the database the 3 are located in, then open editor. From there choose the pull down menu view>data values>data values, choose the appropriate part name,variables, and transactions. Then go to edit>new>variable. Create a new variable. Then go to edit>new>transaction. Make as many new transactions as you need in order to fill the new variable with the 3 variables data. After making the new transactions area's, highlight the data in D1 and hit cntrl-c now move your cursor over to your new variable and hit cntl-v and do the same with the other two variables and you now have a new variable with all transactions in 1 variable.
Thanks for the exercise, I learned something from this too!!!sigpic
If it is NOT the same hole, then you can not 'add' them together, they are seperate, individual entities and MUST be reported as such. I did not say you were adding D1+D2+D3, I said you do NOT have a 90 piece study, but still a 30 piece study with 3 unique variables and Datapage will NOT combine them into a 90 piece study ('cause it's NOT).sigpic
Vondy, Just save you file as an Excel file. (in datapage) file, save as *.xls. You can open it up in excel and format as you like. If you do this a lot you can write a macro to do it for you everytime. If you don't know much about macro's and you do this often PM me and I can help you w/ this.PCDmis 3.5mr2 CAD++
Originally posted by VONDYI Am Checking Three Variables Exactly The Same On One Part And Reporting Out Each, D1, D2, & D3 And Running 30 Parts. What My Boss Wants To See In Datapage Is All Three Combined Together. Instead Of Having D1, D2, & D3 Showing On The Statistics Report, He Just Wants To See One Report. Is There A Way To Combine Them All Together In Datapage? The Samples Have Already Been Ran And The Data Is There, Its Just Not What He Wants To See.
Let us suppose one has a drilling machine that drills a hole then indexes 91º then drills another hole, indexes 91º drills etc. Now let us suppose we want to learn a little about how well the machine indexes 91º. Why would it not be sound to evaluate each 91º index on the part as the same feature even if it is multiple features? The answer is that it is perfectly valid in some cases to do just that(never say never, especially with statistics). Too many people have fallen into believing statistics is limited to nothing more than 30 piece capability studies handed down as a customer requirement to ship product. The most value I have gotten from statistics is not from 30 piece capability studies of key characteristics but studies just as the one you may be trying to do Vondy. I have used statistics to evaluate machine capability, tolerance feasibility, and for process trouble shooting in general. Anyone that tells you statistical analysis must be limited to a single dimension for a single feature that is generated not multiple times on one part by the same process but only from part to part is selling themselves short.
Here is how you can take a 91º angle between multiple features and send them to Datapage as a dimension that treats them as one feature:
Code:CIR1 =FEAT/CIRCLE,POLR,OUT,LEAST_SQR THEO/2,91,0,0,0,1,1 ACTL/2,91,0,0,0,1,1 MEAS/CIRCLE,4,WORKPLANE HIT/BASIC,NORMAL,0.4651,1.9997,0,1,0,0,0.5349,1.9997,0,USE THEO = YES MOVE/CIRCULAR HIT/BASIC,NORMAL,-0.0349,2.4997,0,0,1,0,0.0349,2.4997,0,USE THEO = YES MOVE/CIRCULAR HIT/BASIC,NORMAL,-0.5349,1.9997,0,-1,0,0,-0.4651,1.9997,0,USE THEO = YES MOVE/CIRCULAR HIT/BASIC,NORMAL,-0.0349,1.4997,0,0,-1,0,0.0349,1.4997,0,USE THEO = YES ENDMEAS/ ASSIGN/ARR_ANG[1] = CIR1.PA [color=green]'set an array index (1) here to capture the PA of CIR1[/color] LIN1 =FEAT/LINE,RECT,UNBND THEO/0,0,0,-0.0174524,0.9998477,0 ACTL/0,0,0,-0.0174524,0.9998477,0 CONSTR/LINE,BF,2D,CIR_ORIGIN,CIR1,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 AL_CIR1 =ALIGNMENT/START,RECALL:, LIST= YES [color=green]'create an alignment so your next circle's PA is 91º from the last[/color] ALIGNMENT/ROTATE,XPLUS,TO,LIN1,ABOUT,ZPLUS ALIGNMENT/END CIR2 =FEAT/CIRCLE,POLR,OUT,LEAST_SQR THEO/2,91,0,0,0,1,1 ACTL/2,91,0,0,0,1,1 MEAS/CIRCLE,4,WORKPLANE HIT/BASIC,NORMAL,0.4651,1.9997,0,1,0,0,0.5,2,0,USE THEO = YES MOVE/CIRCULAR HIT/BASIC,NORMAL,-0.0349,2.4997,0,0,1,0,0,2.5,0,USE THEO = YES MOVE/CIRCULAR HIT/BASIC,NORMAL,-0.5349,1.9997,0,-1,0,0,-0.5,2,0,USE THEO = YES MOVE/CIRCULAR HIT/BASIC,NORMAL,-0.0349,1.4997,0,0,-1,0,0,1.5,0,USE THEO = YES ENDMEAS/ ASSIGN/ARR_ANG[2] = CIR2.PA [color=green]'set an array index (2) here to capture the PA of CIR2[/color] LIN2 =FEAT/LINE,RECT,UNBND THEO/0,0,0,-0.0174524,0.9998477,0 ACTL/0,0,0,-0.0174524,0.9998477,0 CONSTR/LINE,BF,2D,CIR_ORIGIN,CIR2,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 AL_CIR2 =ALIGNMENT/START,RECALL:AL_CIR1, LIST= YES [color=green]'create an alignment so your next circle's PA is 91º from the last[/color] ALIGNMENT/ROTATE,XPLUS,TO,LIN2,ABOUT,ZPLUS ALIGNMENT/END CIR3 =FEAT/CIRCLE,POLR,OUT,LEAST_SQR THEO/2,91,0,0,0,1,1 ACTL/2,91,0,0,0,1,1 MEAS/CIRCLE,4,WORKPLANE HIT/BASIC,NORMAL,0.465,2.0084,0,0.9998477,0.0174524,0,0.465,2.0084,0,USE THEO = YES MOVE/CIRCULAR HIT/BASIC,NORMAL,-0.0436,2.4996,0,-0.0174524,0.9998477,0,-0.0436,2.4996,0,USE THEO = YES MOVE/CIRCULAR HIT/BASIC,NORMAL,-0.5348,1.991,0,-0.9998477,-0.0174524,0,-0.5348,1.991,0,USE THEO = YES MOVE/CIRCULAR HIT/BASIC,NORMAL,-0.0262,1.4998,0,0.0174524,-0.9998477,0,-0.0262,1.4998,0,USE THEO = YES ENDMEAS/ ASSIGN/ARR_ANG[3] = CIR3.PA [color=green]'set an array index (3) here to capture the PA of CIR3[/color] ASSIGN/LOOP_INDEX = 1 [color=green]'this variable will count your loops and move to the next index of your array in the loop[/color] ASSIGN/LOOP_COUNT = LEN(ARR_ANG) [color=green]'get the length of the array[/color] V1 =LOOP/START, ID = YES, NUMBER = LOOP_COUNT, START = 1, SKIP = , [color=green]'note that the loop NUMBER property is the length of the loop[/color] OFFSET: XAXIS = 0, YAXIS = 0, ZAXIS = 0, ANGLE = 0 FEATURE_TO_DATAPAGE=GENERIC/POINT,DEPENDENT,POLR,$ [color=green]create a generic point whose PA is set from the array created earlier[/color] NOM/XYZ,2,91,0,$ MEAS/XYZ,2,ARR_ANG[LOOP_INDEX],0,$ [color=green]'notice that LOOP_INDEX is the index number of the array to use[/color] NOM/IJK,0,0,1,$ MEAS/IJK,0,0,1 DIM DIMENSION_TO_DATAPAGE= LOCATION OF POINT FEATURE_TO_DATAPAGE UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV OUTTOL PA 91.0000 0.0000 0.0000 91.0000 0.0000 0.0000 ----#---- END OF DIMENSION DIMENSION_TO_DATAPAGE ASSIGN/LOOP_INDEX = LOOP_INDEX + 1 [color=green]'add one to the index so the next loop will be the next array index value[/color] LOOP/END
CraigLast edited by craiger_ny; 08-30-2006, 04:19 PM.<internet bumper sticker goes here>
You can also, instead of measuring 3 (or however many) features, loop the feature. Code your loop to offset it at whatever angle you need and dimension it in the loop. Be careful there though to code it so your alignment/dimension scheme tracks the angle from hole to hole. I sugest coding the offset yourself, I can post what that looks like if you'd like to see it. The dimension will go over as one feature. I give you these suggestions not knowing how you have programmed it. My first suggestion that I posted code for can be retrofitted to a program you may have written already. If you are going to re-write it then looping the feature about a certain angle might be the cleanest solution. Like I said I can offer nothing now that your data is databased but if you want to do this again in the future you can program the CMM accordingly.
Craig[/quote]
Craig, I would like to see what that would like like also if you could post it.
Thanks,
Vondysigpic
PCDMIS 4.1, 3.5mr2,
Here is how I do it. If you put 91º in the ANGLE property of the loop it will revolve your features at 91º increments regardless of their actual location. What I am doing is measuring a feature at a 91º nominal location. Then I take my generic point "OFFSET_FEATURE" and move it to the same location of the last measured feature. Then I costruct a line that I rotate to. Doing it this way makes the nominal location of your next feature 91º from the last even if the last feature was located at 89.2º from the feature previous to it. Doing it this way will give you data that is purely feature-to-feature so you can evaluate the feature-to-feature variation. That is what I am guessing the intent is. Good luck PM me if you have any questions. I could even take your code and retro mine on it to make it more understandable.
Code:PNT_ORIGIN =FEAT/POINT,RECT THEO/0,0,0,0,0,1 ACTL/0,0,0,0,0,1 MEAS/POINT,1 HIT/BASIC,NORMAL,0,0,0,0,0,1,0,0,0,USE THEO = YES ENDMEAS/ A2 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES [color=green]'this is just a generic alignment scenario yours will be different[/color] ALIGNMENT/TRANS,XAXIS,PNT_ORIGIN ALIGNMENT/TRANS,YAXIS,PNT_ORIGIN ALIGNMENT/TRANS,ZAXIS,PNT_ORIGIN ALIGNMENT/END ASSIGN/POLAR_ANG = 0 [color=green]'this variable will hold the angle of rotation from feature to feature[/color] V1 =LOOP/START, ID = YES, NUMBER = 3, START = 1, SKIP = , OFFSET: XAXIS = 0, YAXIS = 0, ZAXIS = 0, ANGLE = 0 [color=green]'notice I do not offset the angle here. If I did it would not truely be from feature to feature[/color] OFFSET_FEATURE=GENERIC/POINT,DEPENDENT,POLR,$ [color=green]'this is for alignment purposes. This feature acts as an origin of sorts to rotate to[/color] NOM/XYZ,2,POLAR_ANG,0,$ MEAS/XYZ,2,POLAR_ANG,0,$ NOM/IJK,0,0,1,$ MEAS/IJK,0,0,1 CL =FEAT/LINE,RECT,UNBND [color=green]'line from the origin to our offset feature for rotation to[/color] THEO/0,0,0,1,0,0 ACTL/0,0,0,-0.9993908,-0.0348995,0 CONSTR/LINE,BF,2D,PNT_ORIGIN,OFFSET_FEATURE,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 AL_OFFSET =ALIGNMENT/START,RECALL:A2, LIST= YES [color=green]'this alignment will be how we rotate from feature to feature[/color] ALIGNMENT/ROTATE,XPLUS,TO,CL,ABOUT,ZPLUS ALIGNMENT/END FEATURE_TO_DATAPAGE=FEAT/CIRCLE,POLR,OUT,LEAST_SQR [color=green]'this is the feature you want to pattern around the origin[/color] THEO/2,91,0,0,0,1,1 ACTL/2,91,0,0,0,1,1 MEAS/CIRCLE,4,WORKPLANE HIT/BASIC,NORMAL,0.4651,1.9997,0,1,0,0,0.4651,1.9997,0,USE THEO = YES MOVE/CIRCULAR HIT/BASIC,NORMAL,-0.0349,2.4997,0,0,1,0,-0.0349,2.4997,0,USE THEO = YES MOVE/CIRCULAR HIT/BASIC,NORMAL,-0.5349,1.9997,0,-1,0,0,-0.5349,1.9997,0,USE THEO = YES MOVE/CIRCULAR HIT/BASIC,NORMAL,-0.0349,1.4997,0,0,-1,0,-0.0349,1.4997,0,USE THEO = YES ENDMEAS/ DIM DIMENSION_TO_DATAPAGE= LOCATION OF CIRCLE FEATURE_TO_DATAPAGE UNITS=IN ,$ [color=green]'this dimension goes to datapage[/color] GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV OUTTOL PA 91.0000 0.0000 0.0000 91.0000 0.0000 0.0000 ----#---- END OF DIMENSION DIMENSION_TO_DATAPAGE ASSIGN/POLAR_ANG = POLAR_ANG + FEATURE_TO_DATAPAGE.PA [color=green]'now we add to the rotation the actual location of the last measured feature[/color] LOOP/END
Code:* * * OFFSET_FEATURE=GENERIC/POINT,DEPENDENT,POLR,$ NOM/XYZ,2,POLAR_ANG,0,$ MEAS/XYZ,2,POLAR_ANG,0,$ NOM/IJK,0,0,1,$ MEAS/IJK,0,0,1 CL =FEAT/LINE,RECT,UNBND THEO/0,0,0,1,0,0 ACTL/0,0,0,-0.9993908,-0.0348995,0 CONSTR/LINE,BF,2D,PNT_ORIGIN,OFFSET_FEATURE,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 AL_OFFSET =ALIGNMENT/START,RECALL:A2, LIST= YES ALIGNMENT/ROTATE,XPLUS,TO,CL,ABOUT,ZPLUS ALIGNMENT/END * * *
Code:* * * AL_OFFSET =ALIGNMENT/START,RECALL:A2, LIST= YES ALIGNMENT/ROTATE_OFFSET,POLAR_ANG,ABOUT,ZPLUS ALIGNMENT/END * * *
I did not put move points in that loop so you'll need to program accordingly or use clear plane. Play with it, if it makes sense you should have no trouble applying it. Like I said good luck. Statistics can be fun when you get away from the hum drum of Cpk et al.
by TestedI'm trying to get the datapage out put to come out in the same order as the PC DMIS out put but have not found a method that works yet has anyone found...
Channel: DataSuite SPC
12-15-2009, 10:22 AM -
by sdaleyHello,
Trying to transition from DP/rt to DP+ (unfortunately). In DP/rt a variable description can be entered and it appears on all of...-
02-22-2016, 02:33 PM -
DP+ DATA EDITOR:
Variable Set
(New) (Delete)
Need a (Save)...-
09-02-2011, 08:02 AM -
by kpayne
Has anyone ever exported a variable set list out of datapage then sent to another site or out side supplier and had them load into their datapage so...
07-05-2007, 12:18 PM -
For some reason just recently the variables have been flipped around.... as in X Y Z T to T X Y Z. Does anyone know how get it back to the old?
05-23-2014, 02:34 PM -
