I am measuring a cone using the autocone feature on a shaft ( 3 levels, 10 hits each level ) and would like to know how I can report the angle of the cone as it appears on the print. The print calls the angle out as 15 degrees from the taper of the cone to the straight OD section of the shaft. Using the cone angle measurement it reports 30 degrees or the conical angle (included angle). I have tried assigning a variable to the cone measured angle to calculate half of the measured angle to match the print, but it does not seem to be working. Any advise or examples on the best way to do this would be greatly appreciated !!
I am using version 4.2 MR3
Thank you in advance.
