I have a problem...I have chose not to show hits on my edit screen and also not to show features and alignments on the report screen. This had been going good up until about a week ago. It seems like as I continue to write code, all the stuff I unchecked is checked again. The edit screen starts showing all my hits. That's how I know this is going on! I have already opened up a new program and made the changes, then clicked F5, clicked defaults, and then saved and closed the program. It stays fine for a bit, then it goes back to the way it was! Any ideas?
windows layout
Tags: None
I would guess that you open some program that does NOT use those defaults and it is re-setting your defaults to what that program is using. I have seen MY defaults change a couple times (V3.5) and it was due to a supplied program setting MY defaults to match what it had, all without my ever even opening the settings for thos same options. WTF, eh?sigpic
That's redundant to have to go through all that stupid SH*T! Thanks for the help! Matthew, I have been using these defaults since the beginning of time.
Josh
by Jim PoehlerI am running 2009 MR1. As happens with pc-dmis quirks, something new arises that has never been seen before. While executing a lengthy program my desktop...
09-23-2013, 08:51 AM -
by mike dionnewhy does my screen lay change all the time. i have it sit the way i want it and save it, run a check on a part, when i click done, the screen changes...
12-14-2007, 09:32 AM -
by B. JacobsI am wondering if someone else has had this problem. I came in this morning and tried to open a program and all I got was a blank screen. I have no edit...
04-16-2009, 08:22 AM -
by TestedALL FIXED.... SETTINGS EDITER
Does anyone know if there is a setting to force the edit, graphic, and report windws to start up in full screen?...-
10-09-2008, 05:22 AM -
by quadman21Ok, it's gotten a lot worse but what happens is this. I have my edit screen and graphics screen open. I then execute my program. Once the program is finished...
03-14-2008, 09:43 AM -
