I have a metal sleeve that goes into a crankcase cylinder before the die is closed and a shot made. This cylinder has cylindricity called out with a tolerance of .002. I created an auto-cylinder and reported the cylindricity(oh and by the way cylindricity is a new icon on the dimension toolbar in 4.0 and above), it measured in tolerance. I created 4 auo-circles, reported out the diameter and circularity, and 3 of the 4 were OOT for circularity. Can anyone tell me what I am seeing? This doesn't sound right to me? Am not thinking this through properly? Here is a snippet...
Auto-Cylinder info...
DIM CYL1_D= LOCATION OF CYLINDER CYL1 UNITS=IN ,$
D 2.3886 2.3905 0.0025 0.0025 -0.0019 0.0000 -#-------
END OF DIMENSION CYL1_D
DIM CYL1_M= CYLINDRICITY OF CYLINDER CYL1 UNITS=IN ,$
M 0.0020 0.0000 0.0020 0.0000 0.0020 0.0000 --------#
Auto-circle info...
DIM CIR_1_D= LOCATION OF CIRCLE CIR_1 UNITS=IN ,$
D 2.3872 2.3905 0.0025 0.0025 -0.0033 0.0008 <--------
END OF DIMENSION CIR_1_D
DIM CIR_1_M= CIRCULARITY OF CIRCLE CIR_1 UNITS=IN ,$
M 0.0050 0.0000 0.0020 0.0000 0.0050 0.0030 -------->
DIM CIR_2_D= LOCATION OF CIRCLE CIR_2 UNITS=IN ,$
END OF DIMENSION CIR_2_D
DIM CIR_2_M= CIRCULARITY OF CIRCLE CIR_2 UNITS=IN ,$
M 0.0022 0.0000 0.0020 0.0000 0.0022 0.0002 -------->
DIM CIR_3_D= LOCATION OF CIRCLE CIR_3 UNITS=IN ,$
D 2.3890 2.3905 0.0025 0.0025 -0.0015 0.0000 -#-------
END OF DIMENSION CIR_3_D
DIM CIR_3_M= CIRCULARITY OF CIRCLE CIR_3 UNITS=IN ,$
M 0.0019 0.0000 0.0020 0.0000 0.0019 0.0000 --------#
DIM CIR_4_D= LOCATION OF CIRCLE CIR_4 UNITS=IN ,$
D 2.3889 2.3905 0.0025 0.0025 -0.0016 0.0000 -#-------
END OF DIMENSION CIR_4_D
DIM CIR_4_M= CIRCULARITY OF CIRCLE CIR_4 UNITS=IN ,$
M 0.0026 0.0000 0.0020 0.0000 0.0026 0.0006 -------->
Auto-circle info...
