Ok, so here are the specs. B&S Xcel 7-6-5, PC-Dmis 3.7MR2, Win2k SP4.
Problem: When I calibrate a probe, PC-Dmis acts like it doesn't save the qualification results. Lets say I calibrate a 4x50 probe, it will "bump" the sphere like the sphere has moved, even though I know it hasn't. So I will go back and requalify, and tell PC-Dmis that the ball HAS moved, take my one hit on A0B0 and let it go through the motions. If I come back later, it will act like the ball has moved! It is doing this with ALL my probes!
I have made sure the search path for probes is correct, I have deleted ALL the probe files and replaced them with a back up I have used in the past, but nothing seems to work! Is there a file I can delete and replace? What happens if I delete Probe.dat? Will PC-Dmis "re-create" it? I am not having a good day. LOL.
Thanks for any advice.
