Does anybody know how to calculate the t value of an edge point , i tried using the calculation for a vector point but it does not work. I need to calculate the t value manually because pcdmis reported out the wrong t value on some of my edge points.
edge point t value calculation
I, m sorry it was the x value nominal changed and it made the t value incorrect. This was not a new program i have run it several times and for some reason the x nominal on this point changed and only this point. I changed it back but i need to change the t value in datapage , this is why i am looking for the t value calculation.
You may need to do a datapage spreadsheet, recalculate the T's, then replace the actual T's in Datapage.
http://baggy3.info/2centani.gifhttp://baggy3.info/signani3.gif
by keithWell, I thought I had DataPage on the computer, but apparently it's not licensed. I get a missing authorization code error.
At any rate,...-
09-05-2006, 03:14 PM -
by venkat9Can any one explain me the caluculation of "T" value..
02-28-2013, 08:16 AM -
by robehor4Can someone eloberate on what the T value is and why it is evaluated? I have seen this a few times in other threads but Im not sure what it is used for....
01-07-2008, 10:01 AM -
by StoneThrowerhello again gents,
I have been tasked and asked to report the "T" value for points taken on the specimen. this is not an issue,...-
03-21-2016, 08:27 AM -
by JEFMANJJEWELL asked me to put this line here...
The calculation of T value can be write with an assignment like this :
ASSIGN\T_VAL_1=DOT((PT...-
Channel: PC-DMIS Code Samples
09-02-2010, 08:18 AM -
