Well a vendor of my company has purchased an old Zeiss Numerex from the Air Force. Now I am doing a bit of moonlighting, approved and endorsed by my company. I had this guy buy a new computer the last time I was out, and I am in the the process of downloading 3.7 MR 3. Then I get to play the portlock games. But last time I was here we had 3.5 running and the jog box for the machine was funky. It has two joysticks, each with a button, they do not rotate. One is labeled and moves x and y axis, the other moves z, and is labeled for rotation, but it does not rotate the head at the moment. This is a PH50, there is a HCU1 box too, so I believe this is a motorized head. I can track all that down thru Renishaw if I need to. What I need to know is when I made a little program to check the block, I had to keep pushing one of the buttons on one of the joysticks. It acted like an nc machine in single block mode. I can post some pics of the jogbox if that will help. Anyone have any experience with Numerex or Zeiss jogboxes? Many Thanks in Advance.
Need some Zeiss advice
I will post some tomorrow, I don't have access now, I am at home and I only mailed them to my work email. I won't be going back out there until next Friday, so I have some time to see what I can learn about the box. I updated the hasp driver, now they have to call for the .exe file to reprogram it. Thanks for the response though. If your man could/would help, have him send me a PM so I can email or PM him if or when I run into a problem. I am hoping the new computer solved most of what I saw the last time I was out there.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
Wes,
I don't think the joystick for "Z" / "Rotate" will rotate the probe head. Ususally that is for machines with a rotary stage. You should be able to move the probe head with the software though once you get the computer communicating with the machine.-James
Using v3.5 mr2 on a UCC1
James,
You are quite correct. I can rotate with the HCU and also with the software. I am attaching pictures of the box. If anyone is familar with this, I mostly want to know what the functios of the two buttons on the joysticks are, and how I can assign their functions, (if possible). Also, if anyone has experienced a Zeiss machine behaving like an nc machine in single block, what/why/ how do I fix that? I wrote a simple program to align to the block and measure 4 or 5 features, when I executed the program the machine would stop after every move/feature until I pushed one of those joystick buttons, then it would make the next move and stop, etc. TIA
Last edited by Wes Cisco; 05-25-2007, 12:12 PM.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
The PH50 is a motorized head. Rneishaw no longer services them and the replacement is of the PH10 family (not really sure of which model). If the PH50 is still working they were good little units but you could not put anything big or long on it. It was a light duty probe head.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Thanks Dwade,
I plan to check the Renishaw website for full specs. It should be very adequate for this machine and what it will be checking. It seems to measure well enough aside from the need for constant prodding. The owner tells me that when it was installed and calibrated the tech told him it was one of the more accurate machines he had calibrated, for whatever that is worth.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
Originally posted by Wes CiscoWell a vendor of my company has purchased an old Zeiss Numerex from the Air Force. Now I am doing a bit of moonlighting, approved and endorsed by my company. I had this guy buy a new computer the last time I was out, and I am in the the process of downloading 3.7 MR 3. Then I get to play the portlock games. But last time I was here we had 3.5 running and the jog box for the machine was funky. It has two joysticks, each with a button, they do not rotate. One is labeled and moves x and y axis, the other moves z, and is labeled for rotation, but it does not rotate the head at the moment. This is a PH50, there is a HCU1 box too, so I believe this is a motorized head. I can track all that down thru Renishaw if I need to. What I need to know is when I made a little program to check the block, I had to keep pushing one of the buttons on one of the joysticks. It acted like an nc machine in single block mode. I can post some pics of the jogbox if that will help. Anyone have any experience with Numerex or Zeiss jogboxes? Many Thanks in Advance.
By the way neither myself nor the 3rd shift fella know what a cnc does in single block mode, maybe that's where the confusion lies?sigpic
Originally posted by JamesMannesWes, I know you like to push buttons but the 3rd shift fella was kind of wondering... what is the problem/question? What do think the buttons should do?
By the way neither myself nor the 3rd shift fella know what a cnc does in single block mode, maybe that's where the confusion lies?sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
Wes,
Two things...
1 - you can execute a block of commands by highlighting the commands then go file-partial execution-execute block. CMM will execute those commands and stop. Could be something with this but doesn't quite fit.
2 - Breakpoints. Do you have any breakpoints in your program. When the program is running it executes one command at a time. When it gets to a breakpoint it stops. If you press the done button or click continue it will start where it left off. It sounds as if there is a breakpoint after every command. Maybe a setting somewhere?
Originally posted by GoodluckWes,
Two things...
Yep, I do that all the time, not the case here.
Yes, it did act like it would if there had a breakpoint after every movepoint, clearplane, autofeature, etc, but there were not any breakpoints in the program.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
Originally posted by Wes CiscoThanks for the ideas though.
To turn them on go edit-breakpoints-insert defaults.
To turn them off go edit-breakpoints-remove defaults.
I would double check to make sure they are removed.
We have a Zeiss "Eclipse" with the stock Zeiss head on it. I have some, all be it limited, experience on the machine. I have never used the button on the "Z" joystick, but the button on the X/Y joystick is multi-functional (with Calypso software). With Calypso you use this button to set clearance planes in the alignment/clearnace plane phase. When you have a characteristic open and are in the strategy window it is used to set "CMM Positions"=move points. I'm not sure how it works with PC-DMIS though. Hope this helps.Aren Winebrenner
Wes,
I don't know if you've seen the attached documents or if they'll even be of any help. They are explanations of the PC-DMIS machine interface for Zeiss so you might take a look at them.Last edited by Doug Jimison; 08-27-2006, 11:51 AM.sigpic
Is it okay to listen to AM radio in the afternoon?
by kstadHey guys I am back again as of 3 weeks ago they called me back. wish they would have left me on UNC but had to come back.
I have a big problem...-
05-19-2009, 09:10 AM -
by CaemgenI have the Hexagon H000098 universal jogbox with the touchscreen.
The Z is opposite what it is on the Dea Mistral, which I've been using...-
12-10-2013, 12:30 PM -
by BIGWIG7To make a long story short, company bought a new CMM just before I was hired 2 years ago. The CMM machine itself is solid, the main software being used...
07-19-2017, 06:03 PM -
by cmmspmHi -
I have a part up on it's side. I aligned and check everything on one side with the head at A90 B-90. Went above the part, rotated the head...-
09-14-2006, 10:05 PM -
by Paul SarrachI am suffering from the same thing, it will not go into the -x direction. this in on a Vento, Could the TP20 be causeing this? If I take it off an...
03-31-2006, 02:28 PM -
