printing?
  • printing?
    3.7mr2
    I am unable to get my report to print out. I have gone under my print options and marked the box to print (just like I normally do) but when the program finishes running, it does not send to the printer.
    I can preview the edit screen and print, but at the end of the execution the results do not print.
    What am I missing? Why does this happen when you are under the gun?
    One of the things that I have found when I can't print is that someone has checked the draft box.
    Contura Calypso 5.4
      Nope, draft box is unchecked. Print box is checked.
        If nothing else right now, can you print to file then print it out from MS Word?
        Mark Farren
          Okay, figured it out. Needed to right click in the edit window and select Docking view.
          I had an issue earlier and could not see anything in the edit window. I clicked on the Docking view to recover and this caused it to not print or send results to a file. I reselected Docking view and all is well now.
          If I only knew what actually caused this whole mess. The positive side is that I have learned something new.
          Thanks for the help!
