Who's using 4.1 now? What's your quick eval?
They tried to get too fancy;
The report uses a ton of ink and takes up a lot of room. I'm told that you can switch to the old style, but have not find out how yet.
True Position will take you several minutes to dimension one hole. I'm told that you can still do it the old way, but have not found out how yet.
I am having trouble with my toolbars, but have been told that no one else has complained. We put 4.1 on two machines and have toolbar problems with both of them.
4.1 is the lastest and best yet, if you ask Wilcox.
Thank God we did a seperate install and still have 3.7mr3 to work with.
Hey, if 4.1 is the best they have......maybe we should all cancel our maintinance agreement and just stick to 3.7mr.........Ron
TP can be done the old way very simply. Go to insert>dimension> click on legacy dimensions and voila...old style.
If you don't like all the ink being used, whenyou go to Report print setup uncheck the box that says use colors(or something like that). And again voila, no color.
Ask some more and I can provide more.sigpic
I just donwloaded 4.1 and am still playing with it offline and will get it onto our CMMs sometime in the near future and I like what I've seen so far.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Thanks James
I will try that when I get the chance. I have only played around with v4 when it gets slow around here. Any thoughts on my icon trouble. I have used the customize window but can not add any dimensioning icons to the toolbar, the T/P icon is missing. It did let me create a new dimensioning toolbar and I can add whatever I want to it, but the standard dimension toolbar will not.Ron
4.1 in-process
Started to play with 4.1 yesterday. I really like the updated graphics engines...runs smooth. I hope to have them on all 3 machines by mid sept. I have 2 other programmers/operators to worry about. They dont take to kindly to change all the time...have to get them up to speed first....I believe that they are going to the 4.0 class in nov.... we'll see how this plays out with them.
Tim
by cmm_qualityI have been using 3.7mr3 for years and recently upgraded to 4.1.
I have several hypereports that I would like to reuse and or modify slightly....-
01-26-2007, 04:03 PM -
by dccfreakI just installed 4.1 to play around with and I noticed that several .dll files were not registered during the completion of the installation.
08-15-2006, 02:00 PM -
by cesco24We just upgarded our PC-Dmis to 4.0 from 3.7 and I can't figure out what I'm doing wrong on the true position screen. I can't get the #'s to show After...
10-12-2006, 10:51 AM -
by kbottaHow do I change the report text color to black?
Thanks,
Kev-
03-26-2007, 02:45 PM -
by ag1979
I was just wondering, does anyone had any comments on version 4.1?
08-11-2006, 07:21 AM -
