if this has been posted some place else i must apologize, however i was unable to find anything that helped so i'm posting here.
i'm looking to get information from the user about the part and print that input out on the report.
what i have prompts the user with an input window as below:
C4 = comment/input,no,'Please enter any additional information.'
assign/PINFO=C4.input
comment/rept,
,"|| " + PINFO
the problem with this is that if i have multiple lines that i wish to input with a line feed after each one, i can do so by holding the control key while pressing enter. on the surface this seems to work fine but what i end up with the next time i run the program is:
comment/rept,
,"|| " + PINFO
,<second line of info that was entered>
,<third line of info that was entered>
,<fourth line of info that was entered>
and so on which in turn means that i have added hardcoded data to the comment ( which gets printed on the report ) that i would have to go in and remove after each part number. has anyone else experienced this and have any idea how to work around it so that my variable data stays variable data?
comment/rept,
,"|| " + PINFO
comment/rept,
,"|| " + PINFO
