OK, joking aside, I need to know how dmis figures the size of the measured hole. I believe it is a best fit calculation, correct? Is there a way to get it to report the min, such as when you put a gage pin thru the hole? I am currently measuring an assembly that has two halves. Each half has matching holes that don't totally line up. Since this part is bolted to another part, the engineer wants to know what size the thru hole is perpendicular to the part axis. My original thought was to take several hits on each part and project them to a nominal plane then construct a circle. Now I just need to know how to report the min dia of the hole.
Reporting hole size
When you construct your circle from the points, click the Best Fit radio button and choose MAX_INSC (maximum inscribed circle) from the drop down menu instead of LEAST_SQ. This will give you the maximum diameter that will go through the hole. If you were measuring a stud, and wanted to know the smallest hole that the stud would go into, you would use the MIN_CIRCSC (minimum circumscribed circle) option.
PCDMIS 2012
Windows Office XP
Thanks
Thanks NZ
New question same situation. I am using several hits at different levels inside the hole. I am using edge points so that the machine compensates for the location of the surface the hole is in. Is there a way to reference the surface sample of the first level then measure the second and third level. Taking a new sample hit every time makes the program run too long. I thought about setting the axis origin to the sample hit then taking the other levels but I don't want to mix alignment types since I am already using an iterative alignment in the program. Using an auto cylinder won't work because it won't be perpendicular to the cad nominal surface.
I would post my code but one hole worth of code is over 10000 characters.Thanks
Sean Steele
In your autocircle box, do you have 'relative features' on the left about halfway down??
Reference the other levels to the first. 3 sample hits on the first would be better though.
http://baggy3.info/2centani.gifhttp://baggy3.info/signani3.gif
Paul, I am using individual points. I will have to check on the relative feature thing. I would love to be able to take a surface hit on the first point of the level and then reference that for the point on the next two levels. Thanks for the insight. I will let you know if it works.Thanks
Sean Steele
by GWOLLNERLets say I was measuring a 10" inside diameter. Using "find hole" would start at the center and move outward until contacting the part....
11-27-2013, 05:59 PM -
by bswintHi,
New guy here. I have a a cast aluminum block with a cored hole that I need to get correct diameter measurement on. The hole is in the...-
11-26-2018, 09:23 PM -
by dirkoSay you had a pipe with very thin wall thickness and you wanted to pick up a 1 inch hole in the wall. What is the best way to do this? Normally I would...
07-05-2017, 02:21 PM -
by DAN_MHey all,
I am trying to repeatably measure the size of a diameter on a casting. The issue is that every casting is different with regard...-
05-08-2020, 10:34 AM -
by Jeff HuntI've always wondered this... What is the most accurate way of getting the CMM to give you the same measurement on a hole that a pair of calipers would?...
08-19-2009, 03:21 PM -
