PC-DMIS to EXCEL
  • PC-DMIS to EXCEL
    I know this has been covered. I have just downloaded the files from the Wilcox site and have got it to work.
    The question I have is: How do you make dimensions go into the same Excel sheet? I will run a part and it will automaticaly load into the excel sheet. When I run another part(the same kind) it opens a new excel sheet.
    Is there somethng I can do so that all the parts will Load on the same sheet?
    Thanks
    3.5MR2
    B. Jacobs
    B&S Global 12.15.10
    2014.1
    There is a second excel script on wilcox that may be what you want has space for like 50 parts
      The one I have has enough room for 40 parts. For some reason it is now loading on the same sheet.
      Thats what I wanted it to do.
      Thanks for the help Mr. Miller.
      Mr. Miller--I think this is the same one you helped me with about 4months ago and we couldn't get it to work. I just deleted everything that had to do with it today and reinstalled it and what do you know, It is working.
      B. Jacobs
      B&S Global 12.15.10
      2014.1
        If your talking about the one I think you are, it requires you to keep the excel file open while you measure all the parts (ie Capability Study).
          Thats the one. I just leave it open when it Opens up and the program continues to loop. I am running 4 parts in a loop. When I get better at it I am going to try to loop in both the X, and Y. Right now I am just lopping in the Y.
          What I would like is to loop 4 parts in the Y then move in the X and loop 4 more parts in the Y then move again in the X and loop in the Y. I have some code that someone posted(sorry I forget who it was). I am trying to figure it out.
          B. Jacobs
          B&S Global 12.15.10
          2014.1
            Hello all,
            How would I get the Excel file for 4.0? I looked on the wilcox site and it said they don't have a it for aftwer v3.0?
            Thanks,
            John
            Brown & Sharpe "One"
            V. 4.0
            All I wanted was a PEPSI !
              The spreadsheet should work for 4.0. You will more than likely have to open the spreadsheet, go to tool>macros>visual basic editor>tools>references and choose the 4.0 library, and then move it to the top of the list(above your current version's library. Should be good to go.
                Thanks, James-
                I'll give that a shot...
                V. 4.0
                  Pcdmis 3.7 cad++ to excel for 30 parts in the same file
                  Hello
                  Everybody
                  I have the same trouble but i couldn't charge the basic script for my pcdmis 3.7Question which script do I have to use for 3.7 version? and how I can charge all the measurements in columns on excel file?
                  Thanks for your response.
                  B&S
                  Global-image.
                  3.7mr3
                    You should be able to use the same one. You need to change the vb library in the excell form (see other posts)
                      yeah I'm using the pcdmistoexcel_auto.zip, this the name of the script, On the readme says that I have to paste command on the end of the program but i couldn't, it said invalid insertion here, and when I try to insert a basic script on the program and modified like the readme said, we couldn't end the script.
                      could you help me?
                      B&S
                      Global-image.
                      3.7mr3
                        CS1 =SCRIPT/FILENAME= C:\EXCELSCRIPT.BAS
                        FUNCTION/LoadExcel,,
                        STARTSCRIPT/
                        ENDSCRIPT/
                        Thats how I have mine change the name to whatever the script is called and add/change it to say loadexcel
                          yeah I'm trying to use the pcdmistoexcel_auto.zip, The readme file says that i have to paste this command on the end of the program.
                          STARTSCRIPT/
                          ENDSCRIPT/
                          I tried to do it but pcdmis said me "invald insertion here", Also i tried to insert a basic script on the end of the program and modify it But i couldn't end the script,
                          Could you help me..??
                          B&S
                          Global-image.
                          3.7mr3
                            The script will end first time run
                              Ok let me try
                              B&S
                              Global-image.
                              3.7mr3
