I am measuring a I.D. ....dimensioning in True Position. The callout on the drawing is dimension at a Projected distance of 1.500". How do I dimension this ?
Projected distance
True position dialogue box
When you are dimensioning TP there is a box near the bottom of the dialogue that allows you to enter a distance. In your case this distance would be 1.500.
2017 R1 (Offline programming)
by ginnbobTrue position Y dimension is not the same as the distance from plane to feature in the report. I can't figure out why they are not the same. the alignment...
02-06-2020, 05:21 PM -
by J. LuskOk, perhaps I can get the basics on a distance....
Simple: I've got two internal cylinders that intersect, making a cross. One is along...-
08-01-2008, 04:04 PM -
by lucianoI usinng Pc DMIS 4.3 MR1 and I have a question mark about 3d distance .Something is strange for me..must calculate the 3D distance of two circles , I...
03-15-2013, 04:26 AM -
If you need a distance between two features that are offset from each other, what do you do? I've tried a 2D and 3D caliper dimension and the results...
08-29-2013, 12:18 AM -
by bradburrowsHello,
I'm quite new to the CMM universe and I have a measuring task where I'm unsure if I evaluate it correctly.
The task is...-
10-17-2019, 10:37 AM -
